Trans vent relocation
#2904467
03/31/21 06:41 AM
03/31/21 06:41 AM
Posts: 162 Chicago-area Illinois
4mopower
Went to install CSI trans shield and it is obstructed by the trans vent, Would you notch the shield or relocate the vent? The front pump vent is still there are 2 needed?
Thanks, John
Re: Trans vent relocation
[Re: DavidDean]
#2904631
03/31/21 02:22 PM
03/31/21 02:22 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
Modifying the shield will keep it from recerting if you had any interest in that.
I have a shield on mine and I have the vent in the tail housing near the speedometer drive.
68 Barracuda Formula S 340
[Re: dvw]
#2904653
03/31/21 03:43 PM
03/31/21 03:43 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Plug your vent. Relocate it here; Doug That's how mine is done.
[Re: dvw]
#2904664
03/31/21 04:42 PM
03/31/21 04:42 PM
Posts: 16,929 NC
440Jim
NC
Plug your vent. Relocate it here; Doug I like that location (from the Griner instructions), and have used it successfully. I also ground a little drainage in the rib below the new vent (yellow arrows). Some cases have better or worse relief in this rib for drainage.
[Re: cl440]
#2904685
03/31/21 05:35 PM
03/31/21 05:35 PM
4mopower
You shouldn't need 2 vents and you shouldn't need to relocate the vent from the front unless you are running a trans brake. We installed our vent in the top of the tail shaft housing near where it meets the case and ran a rubber hose up to a vented puke tank. This way if it pushes fluid out the vent into the tank it can drain back down into the trans I do have a brake, so your saying I should plug the front vent?
[Re: 440Jim]
#2904726
03/31/21 08:47 PM
03/31/21 08:47 PM
Posts: 11,652 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Plug your vent. Relocate it here; Doug I like that location (from the Griner instructions), and have used it successfully. I also ground a little drainage in the rib below the new vent (yellow arrows). Some cases have better or worse relief in this rib for drainage. I plug the pump on any race unit and relocate it there. Drain is a good idea. The rear support covers most of that area to help prevent oil from blowing out, I use the plastic rearend type vent with the cap. Never had one leak or blow oil out. Cutting that shield will void the certification, and weaken it.
[Re: dvw]
#2904732
03/31/21 08:55 PM
03/31/21 08:55 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: 4mopower]
#2904834
04/01/21 07:51 AM
04/01/21 07:51 AM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
You shouldn't need 2 vents and you shouldn't need to relocate the vent from the front unless you are running a trans brake. We installed our vent in the top of the tail shaft housing near where it meets the case and ran a rubber hose up to a vented puke tank. This way if it pushes fluid out the vent into the tank it can drain back down into the trans I do have a brake, so your saying I should plug the front vent? Yes. Plug the front vent and relocate to the rear.
[Re: dvw]
#2904857
04/01/21 10:10 AM
04/01/21 10:10 AM
Posts: 1,229 In The Hills
jughed
In The Hills
Plug your vent. Relocate it here; Doug Dumb question time...can the relocation drilling/tapping be done to an already built transmission like OP's (or mine), or should the case be stripped beforehand??
[Re: 4mopower]
#2907331
04/06/21 02:36 PM
04/06/21 02:36 PM
Bad340fish
Tulsa OK
I don't know what shifter you have but my strap goes between the NSS and the linkage bracket. I use a turbo action cheetah shifter. Its a little bunched up in there but it works. Unfortunately due to my exhaust system that area is impossible to photograph, I can't even tell you what it looks like just what it feels like LOL.
