Alternator #2904297
03/30/21 02:12 PM
03/30/21 02:12 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Who's alternator are you guys using for your race cars? Looking for something that charges at a lower rpm (say 900-1200 rpm or so) that way it will charge while the car is idling.
Re: Alternator [Re: DusterKid] #2904302
03/30/21 02:22 PM
03/30/21 02:22 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
The Densos should work. AR Engineering makes the brackets to mount them.
http://arengineering.com/home-page/alternator-kits/
Re: Alternator [Re: krautrock] #2904322
03/30/21 03:49 PM
03/30/21 03:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use a GM CS130. It charges a rock solid 14.1 volts from 1000RPM-7000RPM with a 5" pulley crank pulley.
I Run EFI, 2 wideband controllers, two fans, electric water pump, 2 fuel pumps, lights and wipers. I have run every single bit of that for hours on the highway before. This alternator is one of the best mods I have ever done to my car.
68 Barracuda Formula S 340
Re: Alternator [Re: Bad340fish] #2904351
03/30/21 05:54 PM
03/30/21 05:54 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
East Coast Electric makes 1 wire alternators that charge at a low RPM.
https://ecae.com/product-category/alternators/
Re: Alternator [Re: DusterKid] #2904425
03/30/21 10:42 PM
03/30/21 10:42 PM
Power Master 100 amp single wire for GM up
