2.02/2.05 A BIG DIFFERENCE #2903962
03/29/21 12:07 PM
03/29/21 12:07 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Went thru some parts and found some factory 587 heads with a 2.05 intake. Not from factory but from Ryan during the good days. Any significate HP gain over the factory 2.02 with s 525 lift cam?
Re: 2.02/2.05 A BIG DIFFERENCE [Re: A/MP] #2903970
03/29/21 12:29 PM
03/29/21 12:29 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My guy just did this on my modestly prepped eddie heads( 2.02 to 2.05 intake valves) he saw 6-8 cfm at the lower lifts we were focused on( cam is 565 gross lift)
Figure hopefully another 12-15 horse realistically
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 2.02/2.05 A BIG DIFFERENCE [Re: B3422W5] #2904000
03/29/21 01:33 PM
03/29/21 01:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Probably getting to the point where you got to consider bore size, too big of a valve gets closer to the bore and starts shrouding it more than helping. What bore size you talking?
Re: 2.02/2.05 A BIG DIFFERENCE [Re: HotRodDave] #2904033
03/29/21 03:33 PM
03/29/21 03:33 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My head adapter on my flowbench is 4.015 and I run and test all the time with 2.08 valves with almost zero effect. Figure most guys are running 4.030 at least.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 2.02/2.05 A BIG DIFFERENCE [Re: pittsburghracer] #2904068
03/29/21 06:50 PM
03/29/21 06:50 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I asked Ryan this question back in 2017 his answer:
Not enough gain to make it worth spending the $ to do it by itself.......
Maybe 5-8 HP?
Re: 2.02/2.05 A BIG DIFFERENCE [Re: 340Cuda] #2904143
03/29/21 10:55 PM
03/29/21 10:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
When Ryan freshened my ported Edelbrocks years ago he replaced the 2.02's with 2.055's. He said they may pick up 6 or 7 cfm.
Re: 2.02/2.05 A BIG DIFFERENCE [Re: A/MP] #2904194
03/30/21 07:23 AM
03/30/21 07:23 AM
Locomotion Offline
Locomotion  Offline
In some cases the increase in flow can be attributed to a fresh or better valve job and the seat being higher into the chamber with a bigger valve. Sunken valves tend to hurt flow.
