Re: 2.02/2.05 A BIG DIFFERENCE
[Re: A/MP]
#2903970
03/29/21 12:29 PM
03/29/21 12:29 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Went thru some parts and found some factory 587 heads with a 2.05 intake. Not from factory but from Ryan during the good days. Any significate HP gain over the factory 2.02 with s 525 lift cam? My guy just did this on my modestly prepped eddie heads( 2.02 to 2.05 intake valves) he saw 6-8 cfm at the lower lifts we were focused on( cam is 565 gross lift) Figure hopefully another 12-15 horse realistically
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2904000
03/29/21 01:33 PM
03/29/21 01:33 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Probably getting to the point where you got to consider bore size, too big of a valve gets closer to the bore and starts shrouding it more than helping. What bore size you talking?
[Re: HotRodDave]
#2904033
03/29/21 03:33 PM
03/29/21 03:33 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My head adapter on my flowbench is 4.015 and I run and test all the time with 2.08 valves with almost zero effect. Figure most guys are running 4.030 at least.
