Gap at top of fan shroud #2901446
03/21/21 09:33 PM
03/21/21 09:33 PM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
I bought and installed a fan shroud for my 69 Dart. It is the factory type shroud, on an aftermarket aluminum radiator. There is a gap that is just over 1" at the top between the shroud and the tank. Any Ideas on how to fill the gap?? Thanks in advace!!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Gap at top of fan shroud [Re: Prodart440] #2901447
03/21/21 09:39 PM
03/21/21 09:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You might try a rubber seal intended for a pinchweld, that has a flap.
Look at the restorationspecialties.com catalog, should be something there.
Re: Gap at top of fan shroud [Re: Prodart440] #2901452
03/21/21 10:07 PM
03/21/21 10:07 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Following this, my aluminum fan shroud on my 68 has a similar gap. I was going to try using a thick rubber flap attached using sticky tape.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Gap at top of fan shroud [Re: topside] #2901453
03/21/21 10:08 PM
03/21/21 10:08 PM
Avondale AZ
Avondale AZ
I like the idea of something pushing onto the shroud. I'll report back what I find.
Aaron
68 Coronet 440
Re: Gap at top of fan shroud [Re: Prodart440] #2901777
03/22/21 08:20 PM
03/22/21 08:20 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Think closed cell foam,
Just a FEW OFFERNGS ON AMAZON LINKY
Google is also your friend LOL beer
Re: Gap at top of fan shroud [Re: TJP] #2901825
03/22/21 10:48 PM
03/22/21 10:48 PM
Avondale AZ
Avondale AZ
I was thinking something like this. Push it onto the shroud, and it'll rest against the radiator.
Aaron
68 Coronet 440
Re: Gap at top of fan shroud [Re: Prodart440] #2901852
03/23/21 12:24 AM
03/23/21 12:24 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That should also work.
Re: Gap at top of fan shroud [Re: Prodart440] #2902044
03/23/21 01:46 PM
03/23/21 01:46 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I used weatherstrip foam. It can be found in different thickness / widths. Also has an adhesive side which I attached to the radiator so the shroud's edge presses into it. It's not noticeable, easy to replace and closed the gap nicely.
Re: Gap at top of fan shroud [Re: cruzin] #2902163
03/23/21 07:35 PM
03/23/21 07:35 PM
Rochester, New York
GregY Offline
GregY  Offline
Rochester, New York
I used a piece of pipe insulation, it doesn't look too terrible/awful/horrible/horrendous/ugly/disgusting/gross. It does look a little non-factory though...
Re: Gap at top of fan shroud [Re: Prodart440] #2902284
03/24/21 09:16 AM
03/24/21 09:16 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Personally I would first try to determine how much flow you have now with the gap and then after your mod whatever you might end up with. Putting a 1" non-tapered lip on the edge might do more harm to the venturi effect of the shroud than help? The corners of the shroud are somewhat not tapered already. Was just thinking of how any lip that was not tapered on say a carburetor venturi would hurt flow so would that also hurt on a fan shroud?? You could tape short pieces of (kite) string around the top part of the shroud before and after the mod like sometimes done in wind tunnels to check flow? Just maybe the morning coffee talking laugh2 Looks good btw up up And is that F8 Green beer
Could always buy a larger diameter fan and cut it to size if the next size up is too large?
Mike
Re: Gap at top of fan shroud [Re: A12] #2902330
03/24/21 11:54 AM
03/24/21 11:54 AM
Avondale AZ
Avondale AZ
Mike
Yes, F8! I almost painted it orange. I am glad I didn't.
Aaron
68 Coronet 440
Re: Gap at top of fan shroud [Re: Prodart440] #2902885
03/26/21 07:36 AM
03/26/21 07:36 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I used the closed cell insulation "noodles" made to slip over 1/2 copper water pipes. The wall of these tubes is about 3/8" thick. Use a razor blade to quarter it end to end , and attach it to the shroud with 3M weather strip adhesive. It comes with a peel and stick surface to which will hold it in place while you fit& mock up the pieces. Cheap and worked well on the gap with a factory shroud to Champion radiator.
