69 charger Chrysler air tenp decal location?? #2900730
03/19/21 01:29 PM
03/19/21 01:29 PM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
I have a good friend putting together a 69 charger. We were wondering if there is a specific location for these decals or did they just get thrown anywhere on the passenger side rear window? Were they only on one side of the car or were they on both sides? Thanks for any help.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: 69 charger Chrysler air tenp decal location?? [Re: abodyjoe] #2900734
03/19/21 01:38 PM
03/19/21 01:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Rt qtr glass only, on mine it was near the rear bottom corner.
I've also seen them placed forward of that, though.
I'm referring to original cars/decals.
Re: 69 charger Chrysler air tenp decal location?? [Re: topside] #2901080
03/20/21 02:08 PM
03/20/21 02:08 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Never say never with Mopar . . . .on my 70 Sport Satellite, factory AC car . . . tinted glass, all original - NEVER had a AC sticker on rear window ! . . . absolutely no residue of one being on there . . . when I restored the car, I did not put sticker on . . . .
Re: 69 charger Chrysler air tenp decal location?? [Re: a12rag] #2901088
03/20/21 02:18 PM
03/20/21 02:18 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
and/or the original owner hated it & removed it when the car was new - or the new car prep "DUDE" thought it was just a sticker & removed it
Re: 69 charger Chrysler air tenp decal location?? [Re: 6bblgt] #2901106
03/20/21 03:25 PM
03/20/21 03:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Yup. I know I removed one decades ago.
Unless an example is a known original untouched car, anything can happen over time, and often did.
I "personalized" several cars back in the day:
Painted my '69 Dart's grille like a GTS and removed "Western" from its WSS decals, for example.
Pretty much every car around me that was owned by younger folks was modified in some way.
I'm not categorically doubting factory errors, but a lot of people use contaminated evidence as "proof"...
Re: 69 charger Chrysler air tenp decal location?? [Re: a12rag] #2901345
03/21/21 02:28 PM
03/21/21 02:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
This has come up before with the Scat Bee decals in the rear quarter windows also.
The decals are thin and fragile.
That said, in any area with frost an ice scraper used on the inside of the windows just wipes the decals out.
Re: 69 charger Chrysler air tenp decal location?? [Re: abodyjoe] #2901363
03/21/21 03:22 PM
03/21/21 03:22 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
My 68 Dart has it in the lower rear corner of the rear glass. It's crooked from the factory.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 69 charger Chrysler air tenp decal location?? [Re: 6bblgt] #2901365
03/21/21 03:27 PM
03/21/21 03:27 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Back in the day many new car customers asked to have them removed. Personally I took every one off on any car I owned. As far as location right rear quarter glass and the lower rear corner.
Re: 69 charger Chrysler air tenp decal location?? [Re: abodyjoe] #2901479
03/22/21 02:12 AM
03/22/21 02:12 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
One, right rear quarter glass, low as stated....................................................just like the small single pentagon emblem "curb side" on the lower right passenger's (curb)side they wanted those that were walking by to notice it...........also so noticeable when passing all of those non-Mopars grin
Re: 69 charger Chrysler air tenp decal location?? [Re: A12] #2901495
03/22/21 08:08 AM
03/22/21 08:08 AM
Mass
charge70 Offline
charge70  Offline
Mass
I think the location of the A/C decal might be an assembly plant difference.In 1969,Chargers were built in 2 different plants.I have seen that decal at the rear of the 1/4 glass and I have also seen it at the leading edge of the 1/4 glass.It's anyones guess on where that decal actually goes.I can't remember seeing an A/C car without that decal on it.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 69 charger Chrysler air tenp decal location?? [Re: charge70] #2902547
03/25/21 12:34 AM
03/25/21 12:34 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
But always "curb side" and always on tinted glass....................or could you get A/C without tinted glass?
Re: 69 charger Chrysler air tenp decal location?? [Re: A12] #2902554
03/25/21 01:32 AM
03/25/21 01:32 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I recall seeing Chargers with the "Air-Temp" decal forward on the RH 1/4 window - but can't find a picture
tinted glass was recommended, not mandatory & not included - I have a broadcast sheet for a '68 Charger R/T with A/C & clear glass - but have no idea if the car had a decal - I would ASSUME all A/C cars were intended to have the decal
Re: 69 charger Chrysler air tenp decal location?? [Re: 6bblgt] #2902565
03/25/21 06:00 AM
03/25/21 06:00 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
