Howard's is out of cam cores? #2899729
03/16/21 02:55 PM
03/16/21 02:55 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
I'm sticking together an interim 400 for my Plymouth, my initial thought was to keep it simple and run the MP .528 solid.
Did a little reading and decided to try out a Howard's solid with their EDM lifters. This one: https://www.howardscams.com/mechani...383-440-2500-5800-howards-cams-721262-08
Ordered it through Competition Products on 2-2 and was told 5 weeks to grind. Emailed for a status last night and was told Howard's doesn't have a core to grind it on. "They'll get them" but no idea when.
I suppose I could go back to the initial .528 MP plan, but I was hoping keep the duration similar but bump the lift to take advantage of my heads flow potential (B1-BS).
Looking for input on alternatives.
Combo: '65 Sport Fury street/strip. Fresh stock rebuild 400 short block, Brodix B1-BS heads, 6 Bbl intake/carbs, 1 3/4 to 3" headers full 2 1/2" exhaust, Street Hemi 2800 convertor, 28" tire, 323 gears swapping to 3.91/4.10 once it's all back together. Compression will be 9.2ish with 65cc combustion chambers and steel shims.
'65 Plymouth Sport Fury
Blow thru twin turbo coming soon...
Re: Howard's is out of cam cores? [Re: WFO] #2899746
03/16/21 03:39 PM
03/16/21 03:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Wow sorry for your luck with the material shortage. I ordered my Howard's cam through Competition Products and it was an enjoyable experience. That grind sounds very close the the XTQ series Comp Cams sells. I had one very similar to that Howard's grind and I really liked it. I would get with Dwayne (fast68plymouth) and see if they still make that grind.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Howard's is out of cam cores? [Re: fourgearsavoy] #2899750
03/16/21 03:44 PM
03/16/21 03:44 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Gus beer
Try Hughes. Howards makes all their cams. If you look in Howards catalog, every Hughes grind is in it. Maybe something similar on a shelf
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Howard's is out of cam cores? [Re: WFO] #2899757
03/16/21 04:01 PM
03/16/21 04:01 PM
Locomotion Offline
Locomotion  Offline
Would a re-grind of an existing cam be feasible? Might work better if it started out bigger than what you want.
Re: Howard's is out of cam cores? [Re: B3422W5] #2899760
03/16/21 04:12 PM
03/16/21 04:12 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
Gus beer
Forgot about that, good point.
This one looks like the exact same exhaust lobe, with the next step down intake lobe:
http://www.hughesengines.com/Index/...mxhdCBUYXBwZXQsIFNvbGlk&partid=30278
Strange that Howard's and Hughes valve spring recommendations are different.
Re: Howard's is out of cam cores? [Re: WFO] #2899761
03/16/21 04:15 PM
03/16/21 04:15 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Well just for the record so are Comp and Bullet........
Re: Howard's is out of cam cores? [Re: fourgearsavoy] #2899762
03/16/21 04:16 PM
03/16/21 04:16 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
Gus beer
Competition Products was great to deal with, and good pricing too.
Maybe Dwayne will poke his head in here, if not I'll message him.
Re: Howard's is out of cam cores? [Re: sasquatch] #2899763
03/16/21 04:17 PM
03/16/21 04:17 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
Yikes...
Maybe I should try Hughes if they actually have something on the shelf.
Re: Howard's is out of cam cores? [Re: WFO] #2899786
03/16/21 05:28 PM
03/16/21 05:28 PM
mississippi
lostdog Offline
lostdog  Offline
mississippi
Im waiting on my Howard's cam I ordered from Summit on 12/22/2020 and says ship date is late April. Luckily I'm not in a hurry
Re: Howard's is out of cam cores? [Re: lostdog] #2899800
03/16/21 06:02 PM
03/16/21 06:02 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
that's a lot of cam for a small engine in a big car with an automatic transmission. i saw seat timing rated at .020" (if i'm looking at the correct lobe specs). hope you understand what that means.
Re: Howard's is out of cam cores? [Re: lostdog] #2899805
03/16/21 06:10 PM
03/16/21 06:10 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
This cam core shortage isn't new. A year ago I tried to order a big block solid roller from either Crane or Comp Cams but I don't remember which. They didn't have a core and weren't sure when they would. Bullet, at the time said they had a core and could build it,but I opted to use the Cam Motion cam that I already had as the gain would be small vs the cost. It was pre-Covid.My machinist warned me about it as he was already experiencing the problem with cam core issues.As others have stated, this problem has been building for some time. Bill
Re: Howard's is out of cam cores? [Re: lewtot184] #2899814
03/16/21 06:54 PM
03/16/21 06:54 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
I didn't see any .020" numbers.
It's a 246 @ .050 solid cam, so it'll compare to a hydraulic at 236-238 @ .050, nothing out of the ordinary for a street/strip car?
Re: Howard's is out of cam cores? [Re: WFO] #2899836
03/16/21 07:43 PM
03/16/21 07:43 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Go roller
Re: Howard's is out of cam cores? [Re: B3422W5] #2900070
03/17/21 01:29 PM
03/17/21 01:29 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
Did some more digging last night and had forgotten that dude from Hughes is such a boner. Prefer not to give a guy like that my $$.
Guess I'll just go back to my original thought of the MP .528, or maybe call up Racer Brown and see if they have any cam cores. I was always intrigued by that RB solid AndyF ran in his cam test.
Anybody got a .528 solid collecting dust?
Re: Howard's is out of cam cores? [Re: WFO] #2900090
03/17/21 02:38 PM
03/17/21 02:38 PM
Contact Bullet or Ultra Dyne cams scope twocents
Re: Howard's is out of cam cores? [Re: Cab_Burge] #2900096
03/17/21 02:50 PM
03/17/21 02:50 PM
an8sec70cuda Offline
I think all cam cores are in short supply. I'm freshening up a Chevy motor for a friend and waiting on a cam from Isky...they keep saying 3 weeks.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Howard's is out of cam cores? [Re: an8sec70cuda] #2900101
03/17/21 03:16 PM
03/17/21 03:16 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I don't know about the business today, but back when I was involved more heavily in such things Camshaft Machine Company./CMC and Engine Power Components/EPC both in West Michigan
used to make the majority of flat tappet cores for domestic brands and other cam companies....not just Purple Shafts, and they both also did quite a bit of cam grinding
for many different sources and brands. If you've ever noticed "CWC" cast into a cam, that is camshaft machine's tooling.
Lacking resources, for years I assumed it meant "chrysler windsor canada" and was told later on that was incorrect.
Knowing the way the industry is headed, it wouldn't surprise me if those are the next companies on some big ugly conglamerate's buy-up list.
Already happened to crane, comp, edelbrock, etc etc.
Rich H.
Esse Quam Videri
Re: Howard's is out of cam cores? [Re: Cab_Burge] #2900133
03/17/21 04:20 PM
03/17/21 04:20 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
Cab that was on the list until another poster said they were out of cores too.
I've always wanted to run some of UD Harold's lobes.
Re: Howard's is out of cam cores? [Re: ZIPPY] #2900134
03/17/21 04:22 PM
03/17/21 04:22 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
used to make the majority of flat tappet cores for domestic brands and other cam companies....not just Purple Shafts. If you've ever noticed "CWC" cast into a cam, that is camshaft machine's tooling.
Zippy, kinda makes you want to hang on to any cam core you can get in case regrinds start to become a necessity.
On that note I wonder what Delta or Oregon Camshaft have to offer at this point...
Re: Howard's is out of cam cores? [Re: WFO] #2900137
03/17/21 04:39 PM
03/17/21 04:39 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good point!! It also makes me regret scrapping a couple that i have tossed over the last 10 years or so....oops....
Rich H.
Esse Quam Videri
