2021 Ram auto up/down door glass reset? #2899333
03/15/21 12:38 PM
03/15/21 12:38 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Just put a pair of doors on a 21 Ram that hit a deer. They naturally are new door shells. Nothing damaged on the doors as far as regulators or anything like that. Just a swap of parts after they were painted. The front door has the auto up/down function. Usually the rest process has always been roll it all the way down and hold the button in the down position for 3-5 seconds. Then roll it up and repeat. I tried that multiple times with no success. When you hit the button up or down it will roll up or down about 1-2 inches then stop. Didn't matter if either hitting the button once or trying to hold it. It only moved that much either way. I tried having the door open and having the door shut doing the usual reset function and no luck. Anyone ran through this process?
corey
Contact Me about AMD Prices
Re: 2021 Ram auto up/down door glass reset? [Re: hotairballoonpilot] #2900081
03/17/21 01:59 PM
03/17/21 01:59 PM
South Dakota
South Dakota
leads?
Re: 2021 Ram auto up/down door glass reset? [Re: hotairballoonpilot] #2900083
03/17/21 02:15 PM
03/17/21 02:15 PM
N
NITROUSN Offline
NITROUSN  Offline
N
put the window to the bottom - raise the window and hold the "up" button all the way up for three seconds after the window stops moving - lower the window and hold the "down" button all the way down for three seconds after the window stops moving - raise the window and hold the "up" button all the way up for three seconds after the window stops moving.
Re: 2021 Ram auto up/down door glass reset? [Re: NITROUSN] #2900384
03/18/21 02:01 PM
03/18/21 02:01 PM
South Dakota
South Dakota
Nope tried that normal reset trick but no success.
corey
Re: 2021 Ram auto up/down door glass reset? [Re: hotairballoonpilot] #2900399
03/18/21 02:29 PM
03/18/21 02:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
corey
I read what you wrote but if what you did what you wrote you forgot the last step. Read what I wrote carefully.
Re: 2021 Ram auto up/down door glass reset? [Re: NITROUSN] #2900765
03/19/21 02:27 PM
03/19/21 02:27 PM
South Dakota
South Dakota
corey
Ok So every time it stops moving just repeat the 3 second hold? If it is down and moves up just an inch or so. Keep that process going up then same going down?
