lower control arm sway bar brackets? #2898988
03/14/21 12:06 PM
03/14/21 12:06 PM
MotorCity
RC91 Offline OP
RC91  Offline OP
MotorCity
I'm restoring a 71 satellite and am in the process of rebuilding the front suspension, but I'd like to add a factory sway bar. I swear I've seen the brackets for the end links in the ads above as well as at Mancini's and other places, but I've searched to no avail. Have they been discontinued or was I just imagining they once existed? Does anyone know where I could buy a pair? I have another set of control arms with the brackets but I've already sandblasted the originals and replaced the pivot shafts and bushings.
Re: lower control arm sway bar brackets? [Re: RC91] #2899008
03/14/21 12:54 PM
03/14/21 12:54 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
This might be just what you're looking for:
http://www.firmfeel.com/b_body_mopar_front_sway_bar.html
There's mention of adding $50 for cars without a factory front bar.
Mike.
Re: lower control arm sway bar brackets? [Re: moparmike1] #2899286
03/15/21 11:02 AM
03/15/21 11:02 AM
MotorCity
RC91 Offline OP
RC91  Offline OP
MotorCity
Thank you for the reply. It appears that they only sell complete sway bar kits as there isn't any parts list. If I cannot find those control arm brackets separately I'll either make my own or get another pivot and bushing set and clean up the pair of control arms I have with the brackets. The sway bar was a after thought, but since I'm converting to disc brakes I figured I might as well add the sway bar too for a little more safety. This car will be a driver.
Re: lower control arm sway bar brackets? [Re: RC91] #2899323
03/15/21 12:19 PM
03/15/21 12:19 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Hotchkis has them for about $40-50 for the pair.
1972 Dodge Challenger
Re: lower control arm sway bar brackets? [Re: RC91] #2899570
03/16/21 05:50 AM
03/16/21 05:50 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Attached is a fabrication drawing for sway bar brackets I saved years ago and do not know who to thank for it. If I recall, the bracket pairs were cut from a single piece of tube steel. There had been a pretty good thread that documented the fabrication. Not sure if that thread was here or elsewhere.
Re: lower control arm sway bar brackets? [Re: RC91] #2899768
03/16/21 04:38 PM
03/16/21 04:38 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: lower control arm sway bar brackets? [Re: larry4406] #2900312
03/18/21 10:30 AM
03/18/21 10:30 AM
MotorCity
RC91 Offline OP
RC91  Offline OP
MotorCity
Wow! Thanks for the print, screenshot it and saved. That would be a good thing for the tech archives, unless it's already there and I missed it.
Also thanks for the Hotchkiss link. I thought they only sold high end tubular suspension parts.
