Big Block Edelbrock RPM Heads #2898432
03/12/21 01:09 PM
03/12/21 01:09 PM
Wichita, KS
tmef Offline OP
tmef  Offline OP
Wichita, KS
Anyone have experience running them? I am thinking about them but I guess the angle plugs create a clearance issue with some headers. Any info is much appreciated.
Re: Big Block Edelbrock RPM Heads [Re: tmef] #2898433
03/12/21 01:11 PM
03/12/21 01:11 PM
Wichita, KS
tmef Offline OP
tmef  Offline OP
Wichita, KS
Re: Big Block Edelbrock RPM Heads [Re: tmef] #2898447
03/12/21 01:44 PM
03/12/21 01:44 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i used them on my build and they work great. would love to get some dynotime but they work.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Big Block Edelbrock RPM Heads [Re: tmef] #2898471
03/12/21 02:55 PM
03/12/21 02:55 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I got them when they first came out, and they're still working fine.
'69 b body, I tried two sets of headers and two exhaust (among other things) in the pursuit of speed.
For spark plug socket clearance....2 small dings required with hooker competition b body, none required with 2" super competition b body.
Before bolting in a car, put the heads on a bench, bolt the header on and make whatever adjustments you need to make to change
spark plugs. Or do it on an engine stand.
Rich H.
Esse Quam Videri
Re: Big Block Edelbrock RPM Heads [Re: ZIPPY] #2898500
03/12/21 04:57 PM
03/12/21 04:57 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'm running a pair on a 440 in my '65 coronet. i use 2" tti headers and the angle plugs fit nicely. i'm using a fel-pro 8519 head gasket and 2021 will be my 7th year without any issue. the heads i have weren't very nice casting wise so i piddled with the ports a little. they bolted up fine but i had to do some rocker geometry change and they need custom push rods. i think the big issue with them is rocker geometry and push rod length. there's no way a stock valve train would have worked with what i have.
Re: Big Block Edelbrock RPM Heads [Re: lewtot184] #2898554
03/12/21 07:39 PM
03/12/21 07:39 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Same here. '65 Belvedere.
Re: Big Block Edelbrock RPM Heads [Re: tmef] #2898560
03/12/21 08:07 PM
03/12/21 08:07 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I also got a set when they first came out. They have been on 3 different engines now and were ported by MCH. No problems at all with them. 2" TTIs fit just fine.
Master, again and still
Re: Big Block Edelbrock RPM Heads [Re: DaveRS23] #2898624
03/12/21 11:54 PM
03/12/21 11:54 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I run a set OOTB with spring change to accommodate a mild street solid roller cam. On a low deck stroker 470" in a street toy A-body. Been together for 8-10 years with zero issues. Running Comp rockers and Hughes shaft spacers,etc. Makes 500+hp and spins easily to 6K+.
Re: Big Block Edelbrock RPM Heads [Re: Dcuda69] #2898861
03/13/21 10:53 PM
03/13/21 10:53 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
Been running them in my dart with a 383 and pro parts headers. Had to ding the headers a few places but not due to the angle plugs.
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: Big Block Edelbrock RPM Heads [Re: nasty68] #2898887
03/13/21 11:29 PM
03/13/21 11:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Built 6 440's using the angled plug versions. They all cleared the various types of headers we used. 4 of them have been to the track. From mild 12.90's to 10.80's. All were out of the box. All weighed at least 3700 race ready.
Doug
Re: Big Block Edelbrock RPM Heads [Re: dvw] #2898929
03/14/21 07:49 AM
03/14/21 07:49 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Got them on a 521ci motor in a C-Bod weighing in at over 4000lbs.
Daily driver around London Town and yes its been down the strip, in full street trim.
OK it was a hot day and we didn't do any prep, fury 13.20. drumhit
TTI C-Bod headers fitted like a GLOVE! beer
Nearly forgot the best bit, 950cfm carb and 16mpg... drive
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Big Block Edelbrock RPM Heads [Re: Gtxxjon] #2899092
03/14/21 04:34 PM
03/14/21 04:34 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Run them through a competent machine shop to check guide clearance, decks for flat and fix the valve job.
No such thing as ready to run OOTB no matter who builds it.
Kevin
Re: Big Block Edelbrock RPM Heads [Re: tmef] #2899471
03/15/21 07:22 PM
03/15/21 07:22 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
They are good heads. I like to get them bare and have my machine shop finish them. The casings are made in USA but not sure of the valves springs etc.I havent had any problems. 2870 lb challenger with driver runs best of 10.28 12.40 compression 440. Keith
