'71 RR- Where are you hiding your Ignition Control Box? #2896409
03/06/21 11:11 AM
03/06/21 11:11 AM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
I like the factory stock look under the hood, but I also like the reliability and low maintenance of an electronic ignition system. I once hid a control box in the washer reservoir on a '69 Charger but that was easy since it's essentially a hollow box sitting on top of the inner fender. I would prefer not to mount the box under the dash but will do if necessary. I would also prefer not to mount it under the battery tray. So where is everyone hiding their boxes on a '71 B-Body?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2896414
03/06/21 11:22 AM
03/06/21 11:22 AM
GMP440 Offline
GMP440  Offline
When I converted my 68 Coronet to electronic ignition I mounted the ecu on the bottom of the a/c box. Did not drill any holes. I just made a mount that I could attach the the existing holes.
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2896416
03/06/21 11:34 AM
03/06/21 11:34 AM
AndyF Offline
AndyF  Offline
I don't have an ignition box so I don't have to hide it. I don't even have a distributor. When you don't have those things you don't have to hide them.
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: GMP440] #2896417
03/06/21 11:37 AM
03/06/21 11:37 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
It would require a small amount of effort, but is there room on the rad support down near where the front valance is? Near where the valance meets the fender? I thought about that in my charger....
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: moparjim79] #2896426
03/06/21 11:52 AM
03/06/21 11:52 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I put my MSD box, 2 step and fuel pump modulator in the glove box.
Coming soon!!!!
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: moparjim79] #2896428
03/06/21 11:59 AM
03/06/21 11:59 AM
NW New Jersey
NW New Jersey
On the passenger side, the factory washer is long a stretches down to the frame box but maybe there might be a little room there. RRs only have 1 horn but the area where the second horn would mount is too high and easily viewable.
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2896449
03/06/21 01:19 PM
03/06/21 01:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The regular MP ECU fits nicely inside a washer jar, did that on one otherwise-untouched car.
Another good place is below the horns on the rad support.
On another car the MSD box went behind the left headlamp area using a bracket (no added holes).
Under battery tray is a classic spot the OP already mentioned.
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2896479
03/06/21 02:40 PM
03/06/21 02:40 PM
IMGTX Offline
IMGTX  Offline
If you are not looking for stock Chrysler or MSD there is a trick to hide a GM HEI unit under the distributor. A company makes a bracket for it. http://www.designed2drive.com/
Might be an option.
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: IMGTX] #2896500
03/06/21 04:18 PM
03/06/21 04:18 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I went this route on a couple of cars I've owned.
Ron
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RJS] #2896563
03/06/21 07:34 PM
03/06/21 07:34 PM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
i mounted my MSD 6AL under the battery tray in my hemi powered 572ci hemi air grabber 72 roadrunner.
i also left the stock factory electronic ignition system in their original locations.
i powered the MSD by cutting and splicing them together the brown and blue wire going to the ballast just before it left the factory harness. i then ran MSD power wires low along the cowl and then the frame rail to the box. i also ran the coil power wires along the same route and parallel to the factory harness
you had to look pretty hard to not tell it wasn't powered by the factory ignition system.
i had been asked several times how the hemi motor ran with factory ignition system.
perception is 90% of reality
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: Mr T2U] #2896573
03/06/21 08:16 PM
03/06/21 08:16 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
I went with Pertronix system, no need to worry about hiding a box
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: gygeneral] #2896628
03/06/21 10:57 PM
03/06/21 10:57 PM
NW New Jersey
NW New Jersey
Well, looks like there was just enough room inside the long thin washer reservoir. Petronix is good but I like the added features of the Rev-in-ator box.
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2896700
03/07/21 10:24 AM
03/07/21 10:24 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Got to say I have never seen it done this way, good job
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: gygeneral] #2896705
03/07/21 10:44 AM
03/07/21 10:44 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I built a 70 hemi cuda for a guy several years back. Using an M+H harness.
I hid the module inside the car, made a bracket and mounted int to the left side of the brake pedal assy , basically just above your left foot
wiring harness went in using the body plug for the manual washer hose in the firewall
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: gtx6970] #2896708
03/07/21 10:48 AM
03/07/21 10:48 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
My MSD 6AL is hidden under the battery tray. Dial for rev limiter choices is mounted to framerail underneath it.
'63 Dodge 330
11.19 @ 121 mph
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: GY3] #2896710
03/07/21 11:00 AM
03/07/21 11:00 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Hey Viper, you need to fake a coolant line inside that reservoir. Nice job!
Joe
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: jlatessa] #2896750
03/07/21 01:15 PM
03/07/21 01:15 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
always under battery tray or on F bumper bracket somewhere.. [paint it black].. remember heat kills em, so they need to be in the cool airflow if possible..
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: ph23vo] #2896791
03/07/21 03:24 PM
03/07/21 03:24 PM
NW New Jersey
NW New Jersey
I'll just run with the lid off up
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: jlatessa] #2896795
03/07/21 03:31 PM
03/07/21 03:31 PM
NW New Jersey
NW New Jersey
Joe
Joe - I'm going to drop a few ice cubes in there before going for a cruise. Kinda like a Moroso Cool Can smoke
Re: '71 RR- Where are you hiding your Ignition Control Box? [Re: RSI700VIPER] #2897567
03/09/21 10:34 PM
03/09/21 10:34 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
If it’s a big block you can use the same mountingbrackrt from 440 motor homes. It bolts to the rear vally pan rail and is made for the box to mount to
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
