How much fluid?
#2894644
03/02/21 02:42 AM
03/02/21 02:42 AM
Posts: 93 CA
mojavered
CA
Have a leak in 727 trans since rebuild. Have browsed many threads, looked at what others have posted, and checked to see if mine is leaking from same places mentioned too. I “think” I have determined it is leaking from gasket cover for output shaft bearing on rear tail shaft housing. How much fluid should I expect to get out of here if I replace? Car is jacked up, rear end higher than front. Thanks for the help.
71 Challenger RT 440 / 727 / 8.75
Re: How much fluid?
[Re: NITROUSN]
#2895016
03/02/21 09:54 PM
03/02/21 09:54 PM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
That gasket will almost never leak. Look real close where the rear band pivot shaft goes into the case. Reason I say this is taking the tail shaft housing off is required to remove the bands pivot shaft.Look closely you most likely will need a mirror and clean it well and watch. Asking for a friend... If a leak is at the rear band pivot shaft, what is the repair process?
Re: How much fluid?
[Re: moparx]
#2895223
03/03/21 02:20 PM
03/03/21 02:20 PM
Posts: 4,733 Florida
BDW
the dirty, cheap repair is to super clean that area, then fill that area with a quality RTV or silicon adhesive. the proper repair is to remove the pivot shaft and replace the shaft o-ring, which requires some disassembly of components, such as the tail housing and valvebody among others. I did the quick and dirty method and it was leak free for years, still holding up when I changed out to a 518
Re: How much fluid?
[Re: NITROUSN]
#2898896
03/13/21 11:52 PM
03/13/21 11:52 PM
Posts: 93 CA
mojavered
CA
Thanks for the replies. Ended up finding it was speedo internal o ring.
