How much fluid? #2894644
03/02/21 02:42 AM
03/02/21 02:42 AM
CA
mojavered Offline OP
CA
Have a leak in 727 trans since rebuild. Have browsed many threads, looked at what others have posted, and checked to see if mine is leaking from same places mentioned too. I “think” I have determined it is leaking from gasket cover for output shaft bearing on rear tail shaft housing. How much fluid should I expect to get out of here if I replace? Car is jacked up, rear end higher than front. Thanks for the help.
71 Challenger RT
440 / 727 / 8.75
Re: How much fluid? [Re: mojavered] #2894668
03/02/21 08:09 AM
03/02/21 08:09 AM
A727Tflite Online content
A727Tflite  Online Content
Very little if any with the rear raised up.
Re: How much fluid? [Re: A727Tflite] #2894723
03/02/21 10:40 AM
03/02/21 10:40 AM
N
NITROUSN Offline
NITROUSN  Offline
N
That gasket will almost never leak. Look real close where the rear band pivot shaft goes into the case. Reason I say this is taking the tail shaft housing off is required to remove the bands pivot shaft.Look closely you most likely will need a mirror and clean it well and watch.
Re: How much fluid? [Re: NITROUSN] #2895016
03/02/21 09:54 PM
03/02/21 09:54 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Asking for a friend... If a leak is at the rear band pivot shaft, what is the repair process?
Re: How much fluid? [Re: poorboy] #2895194
03/03/21 01:14 PM
03/03/21 01:14 PM
moparx Offline
moparx  Offline
the dirty, cheap repair is to super clean that area, then fill that area with a quality RTV or silicon adhesive.
the proper repair is to remove the pivot shaft and replace the shaft o-ring, which requires some disassembly of components, such as the tail housing and valvebody among others.
beer
Re: How much fluid? [Re: moparx] #2895223
03/03/21 02:20 PM
03/03/21 02:20 PM
BDW Offline
BDW  Offline
beer
I did the quick and dirty method and it was leak free for years, still holding up when I changed out to a 518
Re: How much fluid? [Re: NITROUSN] #2898896
03/13/21 11:52 PM
03/13/21 11:52 PM
CA
CA
Thanks for the replies. Ended up finding it was speedo internal o ring.
71 Challenger RT
440 / 727 / 8.75
