oversize replacement door pins #2892197
02/23/21 11:46 AM
02/23/21 11:46 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
doing a set of 68 b body door hinges and as usual the lower hinge holes are worn. i do not have time to order the oversize ones from RestoRick so trying to find a oversize pin and re-drill. Stock are .342" found jeep ones that were around .360" but they are a tiny bit too short.
anybody have a source for a stock pin from another application i can order?
Re: oversize replacement door pins [Re: chrisf] #2892200
02/23/21 12:05 PM
02/23/21 12:05 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If I remember right Autozone had a generic set of hinge bushings for sale in the help section. Not sure if those might work for you or not.
Re: oversize replacement door pins [Re: mgoblue9798] #2892201
02/23/21 12:07 PM
02/23/21 12:07 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I got a set from Autozone Dorman brand! I don't remember that part number though.
My Monster are real!
Living within your means makes life pretty easy.
Re: oversize replacement door pins [Re: chrisf] #2892203
02/23/21 12:08 PM
02/23/21 12:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
How long do they need to be.
Re: oversize replacement door pins [Re: NITROUSN] #2892211
02/23/21 12:23 PM
02/23/21 12:23 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
stock lower pin is .340" x 3.410" so need a .360-ish x 3.410+
has anyone had any luck bushing the lower pin and it holding up? would prefer oversized metal on metal if possible.
Re: oversize replacement door pins [Re: chrisf] #2892235
02/23/21 01:05 PM
02/23/21 01:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bushing the pins is done all the time on GM stuff.
May save you some grief if your pins are good, but they often are worn themselves.
Re: oversize replacement door pins [Re: topside] #2892348
02/23/21 04:29 PM
02/23/21 04:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Lower hinge is the solid cast one, right. I think I have a decent set of used ones that could make it to BC in a few days !!
Re: oversize replacement door pins [Re: Stanton] #2892404
02/23/21 06:51 PM
02/23/21 06:51 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
i found over sized pins and got them put back together. just like new now. thanks for the replies guys!
i used Dorman 38386 kits which are for 84-96 dodge van and truck. Pins are .372" the most worn part of the hinge was approx .360" quick job once you have the parts.
Re: oversize replacement door pins [Re: chrisf] #2892432
02/23/21 07:42 PM
02/23/21 07:42 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
HI
WHAT WAS THE LENGTH of the 38386 ?
I AM GOING TO NEED SOME FOR A 66 BELVEDERE AD A 73 CUDA .
thank you !
Re: oversize replacement door pins [Re: calrobb2000] #2892467
02/23/21 09:16 PM
02/23/21 09:16 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
they are probably 3/16" longer than the stock pins. just trim them to length. that package comes with larger top pins as well but i used the stock replacement pins and bushings for those ones.
