69 charger roof rail install #2891379
02/21/21 11:11 AM
02/21/21 11:11 AM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
Any one have a picture of the correct screws that
Fasten the roof rail weather strip channel to the roof
Under side.
And what is a proper replacement for the gray
Plumber putty tape that covers the gaps in the
Rail channel where it bends downward along the
A Pillar.
Is 3M spray adhesive ok for the rail to roof gasket
Re: 69 charger roof rail install [Re: 70sate] #2891454
02/21/21 12:53 PM
02/21/21 12:53 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Sorry, don't have pic . . .however, Detroit Muscle Technologies has THE stuff for the gaskets, etc . . . used that on my 70 Sport Satellite, from those to the heater box gasket set, to the body set . . . etc. His stuff is GREAT !!
https://www.detroitmuscletechnologies.com/
Re: 69 charger roof rail install [Re: a12rag] #2891497
02/21/21 02:22 PM
02/21/21 02:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The attaching screws are small Phillips-heads with a flange - shallow dome - about 1/2-5/8 long, silver in color like clear cad plating.
OEM gaskets/seals were a thin white foam, but not visible when installed, so even an adhesive-backed molding tape will work.
Spray adhesive will work for foam, or a few dabs of trim or gasket adhesive.
At the rubber seal's forward ends, and also for the vent window assy forward end at the doors, use 3M strip caulking (aka "dum-dum").
Locations are illustrated in the FSM.
Black Phillips rounded-head screws secure the front ends of the rubber seals, and also the door & quarter seals.
All these screws are #6.
Re: 69 charger roof rail install [Re: topside] #2891540
02/21/21 03:56 PM
02/21/21 03:56 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
Thanks that helps
