Page 1 of 3 1 2 3
Come on ... BE HONEST...what do you properly TORQUE... ? #2890793
02/19/21 10:49 PM
02/19/21 10:49 PM
Florida STAYcation
dOrk ! Offline OP
The village idiot's idiot
dOrk !  Offline OP
Florida STAYcation
... I’ve built a few motors and done lots of mechanical work ... BUT NOT LIKE SOME HERE !
Me ? ... rod and mains.. head bolts ... most times INTAKE BOLTS ...,
BUTTTT ... oil pan and water pump bolts ? ... etc ?? !!
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: dOrk !] #2890806
02/19/21 11:19 PM
02/19/21 11:19 PM
Guitar Jones Offline
Pretty much just cam sprockets, bearing caps and head bolts. But with over 45 years as an auto mechanic I have a pretty good feel for things.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Guitar Jones] #2890808
02/19/21 11:22 PM
02/19/21 11:22 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
On an engine, pretty much everything EXCEPT some intake bolts that there is no way to get a torque wrench on (middle bolts on a 340 come to mind). I also torque lug nuts and some suspension nuts (ball joints, tie rods).
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Jim_Lusk] #2890826
02/20/21 12:14 AM
02/20/21 12:14 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
If I can get a torque wrench on it, I'll do it to spec.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Uberpube] #2890835
02/20/21 02:05 AM
02/20/21 02:05 AM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
Important stuff. Engine internals, things like that. Beyond that, I am pretty well calibrated and can feel what is right.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Ramrod39] #2890892
02/20/21 10:01 AM
02/20/21 10:01 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Anything that specifies more than 30 foot pounds.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Stanton] #2890915
02/20/21 10:51 AM
02/20/21 10:51 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I torque everything that has a specification. I find that even after decades I tend to over tighten smaller fasteners (< 3/8" or so) and under tighten larger fasteners (> 3/8" or so). I've gone to grade 8 on any 1/4" bolt as I pop the stock fasteners like candy. Intake gasket end rails on a BB as one example. The only notable exception is the oil pan. That I use gasket compression to know when to stop.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Stanton] #2890919
02/20/21 10:54 AM
02/20/21 10:54 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Everything.
Even the inner intake bolts
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Sniper] #2890946
02/20/21 11:57 AM
02/20/21 11:57 AM
5thAve Offline
5thAve  Offline
Engine internals, heads and intake gasket. Other then that I mostly only do something if it's hard to get to once everything is fully assembled or if it's a part I don't want to take off again or gasket failure might have been part of the original problem.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: 5thAve] #2890987
02/20/21 12:57 PM
02/20/21 12:57 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Head bolts, rod bolts, main caps, rockers shaft bolts, etc. Don't think I've ever torqued intake bolts, oil pan bolts or anything on the front of the motor for that matter. I'm anal about the tightening sequence though.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: MarkZ] #2890997
02/20/21 01:05 PM
02/20/21 01:05 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Here's a thought too-- is it not just as important to follow the steps/procedure/sequences incrementally as it is to torque to "value"? Example: (generic) lets say head bolts need 110 ftlbs., who feels ok just jammin' them away to said torque spec following the sequence? Or do you go incrementally (20ftlbs, 40 ftlbs, etc)?
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: moparjim79] #2891056
02/20/21 02:37 PM
02/20/21 02:37 PM
Incremental is the way it should be done and the way I like to do it, but let 's face it, unless this is a high performance car it probably isn't going to matter. There is a difference between a race engine and a stock daily driver. For instance, for a driver just torquing rod bolts is fine, for a race engine, the bolt stretch method should be mandatory.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Guitar Jones] #2891076
02/20/21 03:09 PM
02/20/21 03:09 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Head bolts, Rod bearings, main bearings, flywheel bolts, lug nuts. That is about it.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: dOrk !] #2891099
02/20/21 03:47 PM
02/20/21 03:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Since the OP wasn't engine-specific, don't forget lug nuts.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: 6PakBee] #2891132
02/20/21 04:35 PM
02/20/21 04:35 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
About the same here plus I use a torque wrench on the air cleaner wing nut, hose clamps, and trim screws. luck laugh2
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Hemi_Joel] #2891198
02/20/21 08:30 PM
02/20/21 08:30 PM
A727Tflite Offline
A727Tflite  Offline
Just like the vehicle assembly plants - they use DC nut runners on everything.
And the manufacturing plants use them too along with “multiples”.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: A727Tflite] #2891206
02/20/21 08:53 PM
02/20/21 08:53 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
45 years ago couldn’t keep oil pan bolts from coming lose or falling out on the race car, on a whim I looked in a service manual, used the torque and never came lose again. Long story short I torque EVERYTHING I can get to at factory spec.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Hemi_Joel] #2891223
02/20/21 09:27 PM
02/20/21 09:27 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
[/quote]
About the same here plus I use a torque wrench on the air cleaner wing nut, hose clamps, and trim screws. luck laugh2 [/quote]
That was awesome
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: moparjim79] #2891246
02/20/21 10:43 PM
02/20/21 10:43 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Pretty much everything I can get a torque wrench on. I don`t torque valve cover and oil pan bolts as I do them by feel. As a side note, I remember when I was young I asked a mechanic at the local dealer what was the torque spec for main caps bolts and head bolts for a small block mopar. He said I don`t know I just use my air gun and crank them down. I laughed as I thought he was joking. He said I`m not joking I work flat rate and I don`T have time for that. He added that he never has any come backs.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: mopars4ever] #2891251
02/20/21 10:54 PM
02/20/21 10:54 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I find a correlation between the lack of using a torque wrench and leaky valve covers and oil pans.
I am lazy, I prefer to do the job once.
Page 1 of 3 1 2 3
