Re: Come on ... BE HONEST...what do you properly TORQUE... ?
[Re: NANKET]
#2893237
02/25/21 11:08 PM
02/25/21 11:08 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
I can usually tell what torque to apply after many many years of experience as well, however, every one of the front suspension bolts on my current '69 Barracuda restoration are torqued to spec. Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: Sniper]
#2893319
02/26/21 10:40 AM
02/26/21 10:40 AM
Posts: 10,706 North Dakota
6PakBee
North Dakota
Anyone that thinks they can tell how tight something is torqued "by hand" is fooling themselves.
I'm not so sure that applies to all people. When I was going to college I worked part time at the local Chrysler dealer. One thing I did was new car pre-delivery preparation (dealer prep). One of the items on the checklist was to make sure the front wheel bearings were adjusted properly, So I was working on a new car and had the torque wrench out adjusting the front wheel bearings as per the FSM procedure. The senior mechanic walked over and asked me what I was doing. Told him, he laughed that you could do that by hand, didn't need a torque wrench. This is 1974 and I'm young, dumb, and headstrong so I proceed to tell him it can't be done. Now this is a guy that has worked on Mopars since 1947 and has done it all. So it ended up in a challenge. I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again and over the next year I learned a lot from that old fart. Passed away about 20 years go. Great loss of talent. Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head.
[Re: 6PakBee]
#2893374
02/26/21 01:17 PM
02/26/21 01:17 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. I'm about to do that on a 440 Chrysler 300. My plan was a plumbing bar clamp. I would be very interested in his way.
[Re: Sniper]
#2893392
02/26/21 02:17 PM
02/26/21 02:17 PM
Posts: 4,942 WI
Dcuda69
WI
Yep! Our Snap on guy did a demo for our classes at school. None, I mean NONE of us were right on and that includes a few of us with 30+ years turning wrenches. Like I said earlier....new stuff is WAY different than stuff built 50 years ago. If you're not torquing stuff you're begging for come backs.
[Re: 6PakBee]
#2893393
02/26/21 02:20 PM
02/26/21 02:20 PM
Posts: 6,228 nowhere
Sniper
nowhere
I'm not so sure that applies to all people. When I was going to college I worked part time at the local Chrysler dealer. One thing I did was new car pre-delivery preparation (dealer prep). One of the items on the checklist was to make sure the front wheel bearings were adjusted properly, So I was working on a new car and had the torque wrench out adjusting the front wheel bearings as per the FSM procedure. The senior mechanic walked over and asked me what I was doing. Told him, he laughed that you could do that by hand, didn't need a torque wrench. This is 1974 and I'm young, dumb, and headstrong so I proceed to tell him it can't be done. Now this is a guy that has worked on Mopars since 1947 and has done it all. So it ended up in a challenge. I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again and over the next year I learned a lot from that old fart. Passed away about 20 years go. Great loss of talent. Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. Maybe you need to go back and reread how to set front wheel bearing preload. Having just converted my 51 from the original style setup to the later style, such as used in 74, there is no torque on the bearings when you are done.
[Re: IMGTX]
#2893395
02/26/21 02:27 PM
02/26/21 02:27 PM
6PakBee
North Dakota
Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. I'm about to do that on a 440 Chrysler 300. My plan was a plumbing bar clamp. I would be very interested in his way. IIRC what Vern did was use a bar and a block of wood against the firewall. Took a punch and, in combination with the bar, pressed on a side of the plug to turn it sideways. He then pulled it out with a smaller bar. Cleaned the bore up with some abrasive cloth (as I remember this was the worst part), then used a socket and the bar/wood combo to press the plug in. He was leveraging everything off the firewall using the wood block as a spreader. I can't remember him disconnecting the kickdown linkage or the throttle linkage but he must have as this was the driver's side head. This was a mid 60's Chrysler wagon if my memory isn't totally crap today.
[Re: Sniper]
#2893397
02/26/21 02:30 PM
02/26/21 02:30 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
I'm not so sure that applies to all people. When I was going to college I worked part time at the local Chrysler dealer. One thing I did was new car pre-delivery preparation (dealer prep). One of the items on the checklist was to make sure the front wheel bearings were adjusted properly, So I was working on a new car and had the torque wrench out adjusting the front wheel bearings as per the FSM procedure. The senior mechanic walked over and asked me what I was doing. Told him, he laughed that you could do that by hand, didn't need a torque wrench. This is 1974 and I'm young, dumb, and headstrong so I proceed to tell him it can't be done. Now this is a guy that has worked on Mopars since 1947 and has done it all. So it ended up in a challenge. I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again and over the next year I learned a lot from that old fart. Passed away about 20 years go. Great loss of talent. Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. Maybe you need to go back and reread how to set front wheel bearing preload. Having just converted my 51 from the original style setup to the later style, such as used in 74, there is no torque on the bearings when you are done. The procedure still involves a torque spec to arrive at the desired result. Unless you are good at doing it without, and many people are.
[Re: Sniper]
#2893435
02/26/21 04:06 PM
02/26/21 04:06 PM
6PakBee
North Dakota
I'm not so sure that applies to all people. When I was going to college I worked part time at the local Chrysler dealer. One thing I did was new car pre-delivery preparation (dealer prep). One of the items on the checklist was to make sure the front wheel bearings were adjusted properly, So I was working on a new car and had the torque wrench out adjusting the front wheel bearings as per the FSM procedure. The senior mechanic walked over and asked me what I was doing. Told him, he laughed that you could do that by hand, didn't need a torque wrench. This is 1974 and I'm young, dumb, and headstrong so I proceed to tell him it can't be done. Now this is a guy that has worked on Mopars since 1947 and has done it all. So it ended up in a challenge. I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again and over the next year I learned a lot from that old fart. Passed away about 20 years go. Great loss of talent. Sometime I'll tell the story about replacing the casting plug in the end of a 383 head...with the engine in the car....on the end that faces the firewall...without removing the head. Maybe you need to go back and reread how to set front wheel bearing preload. Having just converted my 51 from the original style setup to the later style, such as used in 74, there is no torque on the bearings when you are done. I couldn't find a '74 manual online but this is the procedure from the '73 manual.
[Re: jlatessa]
#2893499
02/26/21 07:57 PM
02/26/21 07:57 PM
RealWing
Ontario, Canada
Yes it is homemade. I attached a photo. If you need some measurements, let me know. Jim
[Re: jlatessa]
#2893540
02/26/21 10:36 PM
02/26/21 10:36 PM
RealWing
Ontario, Canada
Yes, thanks, a couple of dimensions will save me some time. Do the two tabs in front locate in the k frame?
Thanks again, Joe The 2 vertical pieces fit alongside the oil pan and support the engine/K Frame on the oil pan flange. US Car tools has one which is somewhat similar and locates in the K Frame http://store.uscartool.com/Mopar-K-Frame-Stand-Drivetrain-Restoration-Tool_p_84.html
[Re: jlatessa]
#2893773
02/27/21 04:02 PM
02/27/21 04:02 PM
RealWing
Ontario, Canada
Thanks again, Joe Some more photos and dimensions
[Re: 6PakBee]
#2895411
03/03/21 09:48 PM
03/03/21 09:48 PM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
I I'd do it by the book and he'd do it his way and we'd compare. So I set one side and make a small dimple on the nut so you could tell position. Loosened it up and he had a go at it (I covered the dimple with a bit of grease) and......he ended up in EXACTLY the same spot. I never questioned him again . A front wheel bearing is unique. You are compressing 2 tapered wheel bearings. There IS a spot where they get tightened to and most of us can easily find it. Even the range from too loose there is backlash to too tight and it's hard to turn is pretty close to each other. Anything that crushes a gasket like in the engine not only gets torqued to spec but a pattern is important. Rod bolts stretch when torqued properly, also important. I always torque U bolts to rear housing too, it's not as tight as most of you "by feel" think it is. Every wheel and every suspension fastener and if it's crushing a sleeve, at ride height.
