vacume pump pulley question #2889675
02/17/21 03:47 PM
02/17/21 03:47 PM
BigFish69 Offline OP
Has anyone used standard size aluminum crank pulley apposed to a mandrill, and a small pulley on the vacume pump ?
Re: vacume pump pulley question [Re: BigFish69] #2890025
02/18/21 12:25 PM
02/18/21 12:25 PM
an8sec70cuda Offline
No, but if you use a big crank pulley, you'd need an even bigger pump pulley to keep from spinning the snot out of it. I don't know how fast is too fast, but if you use a 4" or bigger crank pulley, the pump pulley would need to be pretty daggum big to slow it down...and I've never seen a pump pulley bigger than 5".
The typical setup is a 3" crank pulley w/ a 5" pump pulley IIRC.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: vacume pump pulley question [Re: an8sec70cuda] #2890041
02/18/21 12:47 PM
02/18/21 12:47 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
an8sec70cuda is correct you don't want to overdrive the pump. here's what Moroso says max rpm is for their various pumps.
"Moroso Vacuum Pump Nos. 22640 and 22641 can be driven no faster than 6500 RPM. The Moroso Vacuum Pump Nos. 22642 and 22643 can be driven as high as 8000 RPM. "
Joe
Without Data, you’re just another guy with an opinion.
Re: vacume pump pulley question [Re: sr4440] #2890245
02/18/21 08:16 PM
02/18/21 08:16 PM
Thanks for verifying my thoughts
Re: vacume pump pulley question [Re: BigFish69] #2890257
02/18/21 08:48 PM
02/18/21 08:48 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Rule of thumb is 50% smaller pulley on crank, larger pulley on vacuum pump
I do 36 vacuum pump pulley and 18 teeth crank pulley.
Or a 24 tooth vacuum pump and 12 tooth crank pulley.
I personally use a Gilmer teeth setup.
Re: vacume pump pulley question [Re: Sammy] #2890401
02/19/21 10:32 AM
02/19/21 10:32 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pretty easy math. If you spin and engine 8000rpm and ruin a 3 vane moroso it will need to be underdriven 20%. If you run say an enhanced 4 vane it can be driven 1 to 1 at 8K. Spinning the pump as close to max rpm as possible will yield the highest vacuum possible as its linear, it wont make 20+ at idle that generally requires a fair amount of RPM not to mention a very well sealed engine.
Re: vacume pump pulley question [Re: Al_Alguire] #2890837
02/20/21 02:33 AM
02/20/21 02:33 AM
Al so the vacuum pump pulley would have to be 20% larger than the crank pulley ?
