No, but if you use a big crank pulley, you'd need an even bigger pump pulley to keep from spinning the snot out of it. I don't know how fast is too fast, but if you use a 4" or bigger crank pulley, the pump pulley would need to be pretty daggum big to slow it down...and I've never seen a pump pulley bigger than 5". The typical setup is a 3" crank pulley w/ a 5" pump pulley IIRC.
