Re-pop Upper Control Arms #2887853
02/13/21 09:56 PM
02/13/21 09:56 PM
A727Tflite Offline OP
Anyone have any comments on the new re-pop upper control arms besides them probably being made in China ?
Anyone use them with good or bad results?
Re: Re-pop Upper Control Arms [Re: A727Tflite] #2888093
02/14/21 01:04 PM
02/14/21 01:04 PM
moparx Offline
moparx  Offline
are they the ones DrDiff sells ?
beer
Re: Re-pop Upper Control Arms [Re: A727Tflite] #2888095
02/14/21 01:04 PM
02/14/21 01:04 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I put a set in a 1968 Charger a few years ago. Fit fine. And as far as I know owner has never had any issues
Re: Re-pop Upper Control Arms [Re: moparx] #2888839
02/15/21 05:32 PM
02/15/21 05:32 PM
beer
Several people offer them.
Vary in price but not sure they are all the same actual manufacturer.
Someone told me they are about .020” thinner material than OE.
Re: Re-pop Upper Control Arms [Re: A727Tflite] #2888957
02/15/21 10:11 PM
02/15/21 10:11 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
FWIW, my original 1969 A-body upper control arms are stamped from 0.150" steel sheet.
Re: Re-pop Upper Control Arms [Re: kentj340] #2889131
02/16/21 11:57 AM
02/16/21 11:57 AM
1971 B Body measures at approx. .185”.
Re: Re-pop Upper Control Arms [Re: A727Tflite] #2890007
02/18/21 11:47 AM
02/18/21 11:47 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
A few years back , I had to return two sets
The ball joints where loose , they are threaded in , not pressed
Went to torque them up , stripped
Another , ball joint was cross threaded , and yes it’s obvious thinner material on the steel
Customer service was excellent on who I bought from at the time
I still have my factory pair - Would bee nice to sandblast , powder coat - The key is though , make sure when removing old ball joints , the threads are still good in the control arms
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Re-pop Upper Control Arms [Re: bee1971] #2890230
02/18/21 07:44 PM
02/18/21 07:44 PM
Thanks for the heads up.
Re: Re-pop Upper Control Arms [Re: A727Tflite] #2899364
03/15/21 02:00 PM
03/15/21 02:00 PM
None
71rm23 Offline
71rm23  Offline
None
Firm Feel?
Re: Re-pop Upper Control Arms [Re: 71rm23] #2899396
03/15/21 03:53 PM
03/15/21 03:53 PM
Originally Posted by 71rm23
Firm Feel?
Several outfits sell them - they appear to all come from the same place, likely China.
I bought a set, we’ll see how they hold up.
They are indeed thinner than production arms. I don’t see an issue as long as I don’t go off roading with my car.
Re: Re-pop Upper Control Arms [Re: A727Tflite] #2899583
03/16/21 08:20 AM
03/16/21 08:20 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I used them and found the ball joints are undersized, I replaced them with Moog and problem solved.
Re: Re-pop Upper Control Arms [Re: HEMICUDA] #2899690
03/16/21 01:39 PM
03/16/21 01:39 PM
moparx Offline
moparx  Offline
undersized in what dimension ?
TIA !
beer
Re: Re-pop Upper Control Arms [Re: HEMICUDA] #2899748
03/16/21 03:41 PM
03/16/21 03:41 PM
Recent purchase or a while back?
What was undersize?
