Re: Re-pop Upper Control Arms
[Re: moparx]
#2888839
02/15/21 05:32 PM
02/15/21 05:32 PM
Posts: 3,069 Michigan
A727Tflite
are they the ones DrDiff sells ? Several people offer them. Vary in price but not sure they are all the same actual manufacturer. Someone told me they are about .020” thinner material than OE.
[Re: A727Tflite]
#2888957
02/15/21 10:11 PM
02/15/21 10:11 PM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
FWIW, my original 1969 A-body upper control arms are stamped from 0.150" steel sheet.
[Re: kentj340]
#2889131
02/16/21 11:57 AM
02/16/21 11:57 AM
A727Tflite
FWIW, my original 1969 A-body upper control arms are stamped from 0.150" steel sheet. 1971 B Body measures at approx. .185”.
[Re: A727Tflite]
#2890007
02/18/21 11:47 AM
02/18/21 11:47 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
A few years back , I had to return two sets
The ball joints where loose , they are threaded in , not pressed
Went to torque them up , stripped
Another , ball joint was cross threaded , and yes it’s obvious thinner material on the steel
Customer service was excellent on who I bought from at the time
I still have my factory pair - Would bee nice to sandblast , powder coat - The key is though , make sure when removing old ball joints , the threads are still good in the control arms
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#2890230
02/18/21 07:44 PM
02/18/21 07:44 PM
A727Tflite
Thanks for the heads up.
[Re: A727Tflite]
#2899364
03/15/21 02:00 PM
03/15/21 02:00 PM
Posts: 2,592 None
71rm23
None
[Re: 71rm23]
#2899396
03/15/21 03:53 PM
03/15/21 03:53 PM
A727Tflite
Several outfits sell them - they appear to all come from the same place, likely China. I bought a set, we’ll see how they hold up. They are indeed thinner than production arms. I don’t see an issue as long as I don’t go off roading with my car.
[Re: HEMICUDA]
#2899748
03/16/21 03:41 PM
03/16/21 03:41 PM
A727Tflite
I used them and found the ball joints are undersized, I replaced them with Moog and problem solved. Recent purchase or a while back? What was undersize?
