Re: Factory steel rim questions
[Re: kbnos]
#288709
04/15/09 10:09 AM
04/15/09 10:09 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
If you find 15x7's with part number 2944450, I'll pay $100 each.
Yea, I bet you would!
The last set of 4 "450" wheels I sold went for over 3K, and they went even higher after that.
The 66-67 14 x 5.5 wheels are hard to find as well, used on 66-67 Hemi cars as well as some other applications, some other big block cars and Station wagons.
They made 3 versions that I've seen so far, all used the large hub cap (pre-1968 style). They were all 5.5" wide but otherwise looked just like a typical 14 x 5.0 wheel.
The most common version had a "5" stamped on both sides of the valve stem and sometimes had 5.5 stamped into one of the raised bumps around the lug nut holes, no other distinguishing stampings. Another version (late 67) had a month & day stamp on either side of the valve stem and a 5.5 stamped off to one side by itself, these also often had the date stamped into the center on one of the raised lug nut pads, this style was the only one of the bunch that had a date code.
1966 Wheels looked identical to the 67's but had an extra hole drilled between each lug not hole (not quite large enough to accept a wheel stud). Some say they have found these wheels on early build 67 cars although I never have. With the hub caps in place you can't see any differences.
Pics to follow are of the 67 style, the black ones are undated, the yellow ones are all dated March 31, 1967.
[Re: president61]
#288715
04/15/09 11:59 AM
04/15/09 11:59 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
went to a salvage yard today to look for 6" steelies for my Coronet. Are these things rare or what? I looked through hundreds of rims, but I was able to find two of them. I also found four 6.5" and several 5.5" rims. All 15inch that accept the smaller dog dish hubcap. I'll be going back in a few weeks and was wondering if there's any other Chrysler steel rims I should look for? THis guy has had this junk yard for 50+ years. Price for the rims are a steep $3 a piece
Look for steelies from '67 and earlier half ton pickups, vans and some '67 and earlier wagons with the tow package. These are 15x5K or 15x5.5K. This info is stamped between the beads, if the tire isn't mounted. These wheels take the large cap and, like Scott's picture shows, doesn't have provisions for wheel covers. I'll pay up to $25/wheel if they're not too rusty. Slightly bent is OK, I just want the centers from them. I'll post a pic of what I want later so you can print it out and take it with you.
[Re: ScottSmith_Harms]
#288716
04/15/09 12:00 PM
04/15/09 12:00 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I like to have the right parts as much as the next guy, and the "450's" are right for my car, but I draw the line in the sand well before paying $3k for a set of steel wheels......I'll just have to make do with my 15" x 7" steely repops from wheel vintiques I guess.
Cheers, Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 64Post]
#288720
04/16/09 02:30 AM
04/16/09 02:30 AM
Posts: 1,044 minnesota
president61
minnesota
sounds good
