SRT spec engine oil ? #2884450
02/05/21 06:40 PM
02/05/21 06:40 PM
Florida STAYcation
dOrk ! Offline OP
The village idiot's idiot
dOrk !  Offline OP
Florida STAYcation
Whatchoousing ?
Re: SRT spec engine oil ? [Re: dOrk !] #2884457
02/05/21 06:53 PM
02/05/21 06:53 PM
Kirkland, Washington
Pacnorthcuda Offline
Didn’t you ask this about 4 months ago?
Re: SRT spec engine oil ? [Re: Pacnorthcuda] #2884459
02/05/21 06:53 PM
02/05/21 06:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Again?!
'63 Dodge 330
11.19 @ 121 mph
Re: SRT spec engine oil ? [Re: Pacnorthcuda] #2884467
02/05/21 07:03 PM
02/05/21 07:03 PM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
Refresh my memory... OTHER THAN padding your post count ! tsk xmaseek
Re: SRT spec engine oil ? [Re: dOrk !] #2884474
02/05/21 07:29 PM
02/05/21 07:29 PM
tboomer Offline
tboomer  Offline
Damn! A double post??? That is obnoxious..... tsk
Re: SRT spec engine oil ? [Re: tboomer] #2884479
02/05/21 07:34 PM
02/05/21 07:34 PM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
Originally Posted by tboomer
Damn! A double post??? That’s a tBlooper .... tsk
fIxEd ... I’ll have one of my Asian babes spank me with a feather smoke
Re: SRT spec engine oil ? [Re: dOrk !] #2884488
02/05/21 07:52 PM
02/05/21 07:52 PM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
Well ... ON TOPIC ....
I was using Valvoline 0-40 ... good stuff but Wally World DOUBLED the price !
Also ... with the front engine shield... isn’t the filter and oil pan cooling hindered?
Or do the SRT engineers like to see that 0-40 oil at a higher operating temp ?
Re: SRT spec engine oil ? [Re: dOrk !] #2884504
02/05/21 08:57 PM
02/05/21 08:57 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
You can use other full synthetic oils of the same weight if you don't like the price. Wal mart now sells 12 quart mobil 1 containers for $50- a decent deal since you have to run 7 quarts.
The reasoning behind the ultra thin weight is not only fuel economy, but the 6.4 is built with much tighter tolerances and needs a thinner oil to effectively lubricate the internals. Dont believe me? I've done an [censored] load of research the last few months related to lifter failures, and part of the research revealed if you pull the oil control solenoid out of the block and its loaded with metal shavings, the entire engine must be replaced- take a guess why.
The front shield you speak of is on all the srt rides. Don't remove it. It serves several purposes designed to benefit the vehicle. It does not contribute to higher oil temps- if concerned, check out your performance pages, it will allow you to monitor all that stuff.
Re: SRT spec engine oil ? [Re: dOrk !] #2884513
02/05/21 09:10 PM
02/05/21 09:10 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
A double post, and both complaining about price. Who could've seen that coming?
https://board.moparts.org/ubbthread...srt-warranty-engine-oil.html#Post2783911
Earning every penny of that moderator paycheck.
DBAP
Re: SRT spec engine oil ? [Re: not_a_charger] #2884530
02/05/21 09:41 PM
02/05/21 09:41 PM
I saw it immediately when he posted it, and everything is too expensive for the Doc!
Re: SRT spec engine oil ? [Re: Pacnorthcuda] #2884572
02/05/21 11:43 PM
02/05/21 11:43 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
One might conclude that Doc has an oil fixation.
'63 Dodge 330
11.19 @ 121 mph
Re: SRT spec engine oil ? [Re: GY3] #2884600
02/06/21 05:08 AM
02/06/21 05:08 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That or his memory is starting to go. laugh2
Re: SRT spec engine oil ? [Re: SNK-EYZ] #2884613
02/06/21 07:58 AM
02/06/21 07:58 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
haha On topic, option 1: Let the dealer change it while it's under warranty.
option 2: Use Mobil 1 and a premium filter then video document the changes while under warranty.
option 3: Don't purchase a vehicle that requires DIY $50 oil changes, expensive brake pads, and pricey tires. twocents
Re: SRT spec engine oil ? [Re: SNK-EYZ] #2884682
02/06/21 12:37 PM
02/06/21 12:37 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
STARTING????? ThIs GeEzEr dOeSn'T KnOw WHaT YeAr iT iS.
Facts are stubborn things.
Re: SRT spec engine oil ? [Re: larrymopar360] #2884740
02/06/21 04:06 PM
02/06/21 04:06 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The way the last year has been in this country (and our foreseeable future for now) I'd forget what year it was if I could. laugh2
Re: SRT spec engine oil ? [Re: SNK-EYZ] #2884760
02/06/21 04:41 PM
02/06/21 04:41 PM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
Day.... ummmm ... tsk xmaseek
Jsta checking in here ... just to see how some of you SNOWED IN apimp are doing !
LOTS going on here in the CHAMPA Bay Area !
Go BUCS ! ... I’ll BE BACK !!!
Re: SRT spec engine oil ? [Re: dOrk !] #2885380
02/07/21 11:57 PM
02/07/21 11:57 PM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
Does THIS NEED to be more specific ??
Re: SRT spec engine oil ? [Re: dOrk !] #2885428
02/08/21 07:35 AM
02/08/21 07:35 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Read what I posted for you.
Re: SRT spec engine oil ? [Re: moparjim79] #2885483
02/08/21 12:07 PM
02/08/21 12:07 PM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
Yo jimBo ... I did and I appreciate it but you should elaborate !
What is EXACTLY the 411 on the 12633 spec ? .... and if THAT is THAT critical... why isn’t that printed on the oil fill cap ?
I called the FCA SRT phone line ... asked which oils are acceptable..... nada
Re: SRT spec engine oil ? [Re: dOrk !] #2885496
02/08/21 12:34 PM
02/08/21 12:34 PM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
Just a FYI to some .....
I’m having some issues with the connection to this site ...
It will RELOAD at a whim ... and I lose all I've typed
