Re: Trick Flow 240 heads
[Re: sjs64polara]
#2885911
02/09/21 04:05 PM
02/09/21 04:05 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Nice truck! It would be a hoot with a street friendly 541 torque monster like I'm screwing together for my Imperial. No doubt it is of similar weight. A High Strung rev happy engine would be a wee bit out of place in that thing.
[Re: feets]
#2885917
02/09/21 04:18 PM
02/09/21 04:18 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I Love the truck! Very clean and perfect candidate for a sneaky stroker. Please post some more pics when you can. Id like to do a truck build as well.
As for the TF 240 heads, I used them on a 505 pump gas stroker in a 72 Challenger - w a 248@.050 solid flat tappet, 950 carb, 4speed and 3.55's and it was an absolute blast on the street. No dyno numbers, but endless torque and tire shredding power in any gear. Highly recommend the TF heads.
2 kids and a dog
[Re: HardcoreB]
#2886068
02/09/21 10:05 PM
02/09/21 10:05 PM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
Thanks for the updates and good luck with the new truck! Hate to hijac but you have the '64 down into the 8.5's now?!!! Is it still 3400lbs? What are the newest motor details? if you don't mind. No major changes to engine. Weight is very close to 3400. Engine is 588. 572-13 heads,Sheet metal manifold, and cam from Goodwin. Carbs are billet Pro systems. Makes 1200 hp NA. Ladder bar, 10.5 tire. Pro Trans is custom built per shared specs from Dave and myself. Had many headaches and transmission failures over the years. ......
[Re: TonyS451]
#2886072
02/09/21 10:16 PM
02/09/21 10:16 PM
sjs64polara
Wisconsin
That’s totally awesome! My bother runs TF heads on his Comet and his car rocks. My boys are now to the age that they want to help build an engine. I’m totally jazzed they want to help. A good strong street engine will be perfect for the truck. Thanks for input
