Trick Flow 240 heads #2882292
01/31/21 09:17 AM
01/31/21 09:17 AM
Wisconsin
sjs64polara Offline OP
Wisconsin
Been years since I’ve posted on this forum. I knew everyone would give constructive feedback here. I’m considering these heads for my 77 Dodge W150. I plan to use the Atomic MSD full injection which is new to my world. The plan is to have the truck as a fun street toy. Mainly for cars shows and cruising around town. Most likely I’d build a stroker, nothing over 500 inches. Actually the whole truck thing is new to my world. For those that know me, my 64 High Strung car has been my live for the last 14 years...
21C47C2E-DABA-47BC-8A97-2E4C8501773A.jpeg126E75A3-1317-4F2D-8548-EFAC9538774B.jpeg6D63FC92-07DB-4B13-A74F-07E3E908EEDF.jpeg
Re: Trick Flow 240 heads [Re: sjs64polara] #2882297
01/31/21 09:34 AM
01/31/21 09:34 AM
Welcome back, I like your truck up
Re: Trick Flow 240 heads [Re: RapidRobert] #2882303
01/31/21 09:53 AM
01/31/21 09:53 AM
tboomer Online work
tboomer  Online Work
And I like your car! up
Re: Trick Flow 240 heads [Re: tboomer] #2882961
02/01/21 11:11 PM
02/01/21 11:11 PM
Wisconsin
Wisconsin
Thanks, it’s been a heck of a journey. Been tweaking on this thing for years. The 10.5 tire has brought many challenges over the years, mainly fun. I’m racing my brother in the enclosed picture. I believe he ran 8.21 vrs my 8.52. This truck is a completely different world for me. My teenage boys love trucks so I thought why not a early mopar for a project. First thing they said was “dad this thing is a dog”. Guess racers are family bread
Re: Trick Flow 240 heads [Re: sjs64polara] #2882989
02/02/21 02:48 AM
02/02/21 02:48 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
That is one awesome truck . I like that stance it has . Very clean as well . I do remember your car also . Do you still run NSS races ? Goodwin power ? If so I met you at one of the Muncie races the last couple years . Thanks for posting . Gary
Re: Trick Flow 240 heads [Re: Gabby63] #2883081
02/02/21 12:43 PM
02/02/21 12:43 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Nice truck! I have 78 power wagon. Wish i could have found one with the ex cab. They are hard to come by.
Re: Trick Flow 240 heads [Re: Gabby63] #2884641
02/06/21 09:59 AM
02/06/21 09:59 AM
Wisconsin
Wisconsin
Yep, still heads up racing in NSS with Goodwin.
Re: Trick Flow 240 heads [Re: sjs64polara] #2885811
02/09/21 11:20 AM
02/09/21 11:20 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Thanks for the updates and good luck with the new truck! Hate to hijac but you have the '64 down into the 8.5's now?!!! Is it still 3400lbs? What are the newest motor details? if you don't mind.
Re: Trick Flow 240 heads [Re: sjs64polara] #2885911
02/09/21 04:05 PM
02/09/21 04:05 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Nice truck!
It would be a hoot with a street friendly 541 torque monster like I'm screwing together for my Imperial. No doubt it is of similar weight. A High Strung rev happy engine would be a wee bit out of place in that thing.
- Stu Harmon
Re: Trick Flow 240 heads [Re: feets] #2885917
02/09/21 04:18 PM
02/09/21 04:18 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I Love the truck! Very clean and perfect candidate for a sneaky stroker. Please post some more pics when you can. Id like to do a truck build as well.
As for the TF 240 heads, I used them on a 505 pump gas stroker in a 72 Challenger - w a 248@.050 solid flat tappet, 950 carb, 4speed and 3.55's and it was an absolute blast on the street. No dyno numbers, but endless torque and tire shredding power in any gear. Highly recommend the TF heads.
2 kids and a dog
Re: Trick Flow 240 heads [Re: HardcoreB] #2886068
02/09/21 10:05 PM
02/09/21 10:05 PM
Wisconsin
Wisconsin
No major changes to engine. Weight is very close to 3400. Engine is 588. 572-13 heads,Sheet metal manifold, and cam from Goodwin. Carbs are billet Pro systems. Makes 1200 hp NA. Ladder bar, 10.5 tire.
Pro Trans is custom built per shared specs from Dave and myself. Had many headaches and transmission failures over the years.
Re: Trick Flow 240 heads [Re: TonyS451] #2886072
02/09/21 10:16 PM
02/09/21 10:16 PM
Wisconsin
Wisconsin
That’s totally awesome! My bother runs TF heads on his Comet and his car rocks. My boys are now to the age that they want to help build an engine. I’m totally jazzed they want to help. A good strong street engine will be perfect for the truck. Thanks for input
