Re: Are new intake designs needed for big engines?
[Re: lewtot184]
#2884591
02/06/21 02:55 AM
02/06/21 02:55 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
i would think the real issue is building for 5300lbs and 3.23 gear. what are the goals? i don't think there is one correct answer for the question of manifolds. It might be difficult to believe but there's more to life than drag racing. This is a plus-sized cruiser that is the perfect candidate for silly amounts of torque. Think of the Mercedes S65 AMG. A 5.5 liter twin turbo V12 cranking out 635 hp and 720 lb/ft in a 5300 lb sedan. Why? Because they can. I'm building it because it's my car, my engine, and I want to do it. The car is so big it's a bit absurd. You just can't take it seriously. However, it cruises down the highway like nothing else. I like having a little fun with my stuff and being just a wee bit different in my builds. Anyone can build a cookie cutter car by following the same old thing everyone else has done. That's boring.
[Re: feets]
#2884611
02/06/21 07:44 AM
02/06/21 07:44 AM
Posts: 3,916 usa
lewtot184
usa
i would think the real issue is building for 5300lbs and 3.23 gear. what are the goals? i don't think there is one correct answer for the question of manifolds. It might be difficult to believe but there's more to life than drag racing. This is a plus-sized cruiser that is the perfect candidate for silly amounts of torque. Think of the Mercedes S65 AMG. A 5.5 liter twin turbo V12 cranking out 635 hp and 720 lb/ft in a 5300 lb sedan. Why? Because they can. I'm building it because it's my car, my engine, and I want to do it. The car is so big it's a bit absurd. You just can't take it seriously. However, it cruises down the highway like nothing else. I like having a little fun with my stuff and being just a wee bit different in my builds. Anyone can build a cookie cutter car by following the same old thing everyone else has done. That's boring. i'm the kind of person that "if i can't drive it, i don't want it". driving it can mean compromises in performance sometimes and i've always been ok with that. i use a ch28 for my torquey cruiser and really like it.
[Re: feets]
#2884731
02/06/21 03:18 PM
02/06/21 03:18 PM
Posts: 670 Los Osos, Ca
CKessel
Los Osos, Ca
i would think the real issue is building for 5300lbs and 3.23 gear. what are the goals? i don't think there is one correct answer for the question of manifolds. It might be difficult to believe but there's more to life than drag racing. This is a plus-sized cruiser that is the perfect candidate for silly amounts of torque. Think of the Mercedes S65 AMG. A 5.5 liter twin turbo V12 cranking out 635 hp and 720 lb/ft in a 5300 lb sedan. Why? Because they can. I'm building it because it's my car, my engine, and I want to do it. The car is so big it's a bit absurd. You just can't take it seriously. However, it cruises down the highway like nothing else. I like having a little fun with my stuff and being just a wee bit different in my builds. Anyone can build a cookie cutter car by following the same old thing everyone else has done. That's boring. And when you blow by some ricers/late stang-camaro-chally gents, racing on the freeway, with 6 or more friends in the yacht its all the more satisfying.
Carl Kessel
[Re: hemienvy]
#2884962
02/07/21 07:57 AM
02/07/21 07:57 AM
Posts: 1,629 pa
572charger
pa
so i had a indy tunnel ram on my 605 cuin hemi for 3 years i had 2 1050 dominators on it tryed all kind of jetting and timing and air bleeds,,, then i got a raybarton 4500 single dominator intake and a 1250 carb and it picked up 3 tenths and 3.5 mph over the tunnel ram on the 1st pass !!!! [censored] thats my kind of luck though
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: CKessel]
#2885079
02/07/21 01:10 PM
02/07/21 01:10 PM
feets
Senior Management
Senior Management
Irving, TX
And for a short time I'll be in front of them and behind them at the same time. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
[Re: Moparite]
#2885081
02/07/21 01:12 PM
02/07/21 01:12 PM
feets
Senior Management
Senior Management
Irving, TX
How about the mod man intake, You can run a single 4BBL, 6 pack or duel quads depending on what top you use. Modman is quite adaptable but extremely expensive. Those short runners are not likely to be of much benefit to a moderate RPM engine like most people use on the street.
[Re: feets]
#2885119
02/07/21 02:19 PM
02/07/21 02:19 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
And for a short time I'll be in front of them and behind them at the same time. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) . ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) .
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: feets]
#2885332
02/07/21 09:39 PM
02/07/21 09:39 PM
Posts: 3,916 usa
lewtot184
usa
How about the mod man intake, You can run a single 4BBL, 6 pack or duel quads depending on what top you use. Modman is quite adaptable but extremely expensive. Those short runners are not likely to be of much benefit to a moderate RPM engine like most people use on the street. and, too much plenum volume. might make a good blower manifold.
[Re: Moparite]
#2885465
02/08/21 11:13 AM
02/08/21 11:13 AM
Posts: 4,213 New York
polyspheric
New York
The complex interior design and advantages are clearly visible. Or, it's a shoe box...
Boffin Emeritus
[Re: polyspheric]
#2912434
04/20/21 05:03 PM
04/20/21 05:03 PM
Posts: 100 Louisiana
BiomedTechGuy
Louisiana
It looks like a shoebox got dropped in a vat of molten aluminum, BUT I'm most likely going to run the ModMan BECAUSE By my own mandate, my 541 MUST HAVE A 6BBL. So, I am fortunate to have bought a beautiful example of the Weiand P3690982 6bbl intake, the "old school" Super Stock intake that far too much research for any sane person has informed me makes the most power when a 6bbl is the choice of carbureation, other than a custom intake. BUT I also can't bring myself to run TF 240s on a 541 Bill Mitchell aluminum RB block So, that means Max Wedge port size and TF 270s. The Weiand can probably have material added to the cylinder head end of the runners and then hogged out to MW ports, but I don't think that the runners have enough meat to open them up to the plenum floor AND I am hooked on the look of my N96 Air Grabber hood on my 70 V-code Roadrunner So, that leaves me needing a 3x2bbl intake that will do some degree of justice for my 541 cu in Bill Mitchell aluminum block based stroker motor in my 5 speed, 4:10 geared mostly street driven Roadrunner. That leaves me with the ModMan. Indy still will CNC the ports to MW size for $100 If I switch over from my Promax modded Holley carbs to a 3x2 F&B DPI/EFI I'm sure the ModMan would work even better, but I have to start with the Holley carbs. If by some tragedy the ModMan doesn't fit with the Air Grabber, then I'm left with the factory aluminum dual plane 6bbl intake, or give up my beautiful hood, go to a "tall" 6 pack scoop, and that would make me consider a custom top for a 6bbl 440-25 setup or see what can be done with the Weiand as far as porting. I have the Innovate Motorsports DLG-1 dual wideband O2 sensor system.
