Page 3 of 3 1 2 3
Re: WHO SELLS THOSE REPO BATTERIES [Re: charge70] #2803611
08/01/20 10:26 AM
08/01/20 10:26 AM
Alabama
David1971 Offline
David1971  Offline
Alabama
Originally Posted by charge70
Originally Posted by David1971
Has anyone purchased one of the Group 24 or 27 reproduction batteries from Battery Central Mall? If so, are you satisfied with your purchase?
https://www.batterycentralmall.com/Batteries/TurboStart/Plymouth.html
Thanks,
David
I bought 2 Group 27 batteries from the Mall,no problems here.
I sent an email to them inquiring about their repro batteries. This is the response that I received:
"All classic car batteries right now have a small AGM battery in a reproduction case. These AGM batteries used in the reproduction case are the same batteries used by racers. The caps are for cosmetic purposes only and the caps on these batteries do come off. "
But I forgot to ask about charging. Do the AGM racing batteries;Odysssey, TurboStart, etc. require a special charger? I have been using Battery Tenders for my lead acid batteries.
David
Re: WHO SELLS THOSE REPO BATTERIES [Re: David1971] #2803660
08/01/20 11:31 AM
08/01/20 11:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
and what are the specs on them?
Re: WHO SELLS THOSE REPO BATTERIES [Re: David1971] #2803672
08/01/20 11:51 AM
08/01/20 11:51 AM
WA
tman Online content
tman  Online Content
WA
If it's an AGM, then any charger compatible will work. The newer Battery Tenders will work with AGM. Just have to look up the specs.
Re: WHO SELLS THOSE REPO BATTERIES [Re: Kowal] #2804025
08/02/20 01:31 AM
08/02/20 01:31 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Originally Posted by Kowal
Originally Posted by Pacnorthcuda
Originally Posted by RSI700VIPER
I just ordered a group 27 red cap battery on line for $359 which includes shipping. According to the web site, they are in stock. The batteries are now maintenance free (sealed) batteries so hopefully they will last longer than the just I'm used to getting.
Do us a favor and post the weight of it when you get it! As I already posted, my Turbostart Axion group 27 that I bought in Jan 2011 weighed 58 pounds! Was still starting my 440 nine years later when I killed it and gutted it last week. Damn good battery, damn heavy.
I have a red cap turbo start battery that just died. Also had it since 2011, too bad it finally gave up. Anyway, what are you doing to gut it and replace the insides? What have you bought to go inside, or are you not that far yet?
I did mine, unlike others I have seen I cut the top off to be used as a lid. This also left the whole case intact.
I treadled the post and screwed the post in but may just bolt a cable to them and then onto the new battery inside.
I also epoxied some plastic angle {like angle iron} to hold the top in place but the factory hole down would work. I kinda go past what is needed at times.
I polished the rubber case as seen in the picture with Yellow Caps. And have 2 sets of caps in case I want the 24 to look like a 27 I kinda go past what is needed at times.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: WHO SELLS THOSE REPO BATTERIES [Re: 340SIX] #2804155
08/02/20 12:16 PM
08/02/20 12:16 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
Nice work! What type of tool did you use to cut through the case?
Re: WHO SELLS THOSE REPO BATTERIES [Re: David1971] #2831232
10/10/20 04:55 PM
10/10/20 04:55 PM
WA
tman Online content
tman  Online Content
WA
Just received an email from Mancini's that the red top batts from Turbostart are in stock, but says to call them. But you can buy from Summit or Jegs too. Summit says est delivery date is 10/26.
https://www.manciniracing.com/trbs27mrla.html
Re: WHO SELLS THOSE REPO BATTERIES [Re: tman] #2831252
10/10/20 05:52 PM
10/10/20 05:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
$299.99 from Summit. Hmm, I wonder where I can find a Summit 10% off coupon ?
Re: WHO SELLS THOSE REPO BATTERIES [Re: mopars4ever] #2883862
02/04/21 01:28 AM
02/04/21 01:28 AM
WA
tman Online content
tman  Online Content
WA
I have a repro Group 27 red cap battery core that anyone can have to gut out. It is an old Turbostart AGM so no wet cells. Pick up only in the Seattle area. This battery lasted 10 yrs and still starts up the 440, but the cranking is slow.
Re: WHO SELLS THOSE REPO BATTERIES [Re: tman] #2883969
02/04/21 12:49 PM
02/04/21 12:49 PM
California
mickm Offline
mickm  Offline
California
I gutted mine as well. I don't remember how long it lasted, but not more than 3 or 4 years at most.
I put a Odyssey PC925 in it. That was 3 years ago, and it too is starting to crank slow. But better a $157 replacement.
Should have taken more pictures, but here we are.
Re: WHO SELLS THOSE REPO BATTERIES [Re: mickm] #2884021
02/04/21 02:25 PM
02/04/21 02:25 PM
Kirkland, Washington
Pacnorthcuda Offline
I am maintaining my Odyssey PC925 on a Battery Tender Jr even though it’s not recommended. IMO the charging issue boils down (ha! Pun intended) to whether or not the Charger reaches float stage and drops voltage down to around 13.3, which last I checked mine does.
Re: WHO SELLS THOSE REPO BATTERIES [Re: Pacnorthcuda] #2884055
02/04/21 04:17 PM
02/04/21 04:17 PM
WA
tman Online content
tman  Online Content
WA
X2
Re: WHO SELLS THOSE REPO BATTERIES [Re: tman] #2884122
02/04/21 07:55 PM
02/04/21 07:55 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I have a modern Mopar group 27 in my car. date on it is 2011
Still cranks pretty quick
When the time comes I will put another one in it. I dont need a $300 and up battery in my car
Re: WHO SELLS THOSE REPO BATTERIES [Re: gtx6970] #2884210
02/05/21 05:35 AM
02/05/21 05:35 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I wish someone sold just the cases, so people can modify their own. I think folks would buy more of them if they had an option.
Re: WHO SELLS THOSE REPO BATTERIES [Re: migsBIG] #2884241
02/05/21 09:33 AM
02/05/21 09:33 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Yes, this would be the answer for plenty of us.
Mike.
Re: WHO SELLS THOSE REPO BATTERIES [Re: moparmike1] #2885341
02/07/21 10:02 PM
02/07/21 10:02 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
If Jim’s (Antique Auto Batt) is still going, they have my full support. I have an eight year old group 24 that is still going strong when their maintenance instructions are followed. Bought another two years ago for another car and no issues.
Re: WHO SELLS THOSE REPO BATTERIES [Re: 340cpe] #2885372
02/07/21 11:38 PM
02/07/21 11:38 PM
WA
tman Online content
tman  Online Content
WA
I ordered my battery from Battery Central Mall. I spoke to Wayne there and he advised that the battery will be coming from Jim's battery mfg. It will take about 6 weeks. I received my battery within that time frame and the box it came in has Jims battery logo on it. In fact it came in last week. I ordered during xmas week. So far so good. I agree, it would be nice if they just sold the case. Jim's website is not so good but he does have one.
https://jimsbatterymfg.com/shop/
Re: WHO SELLS THOSE REPO BATTERIES [Re: mickm] #2885624
02/08/21 05:54 PM
02/08/21 05:54 PM
340SIX Offline
340SIX  Offline
Good job.
I seen guys who cut bottom put but cutting the top off to.me is the way to go.
Re: WHO SELLS THOSE REPO BATTERIES [Re: 340SIX] #2885638
02/08/21 06:44 PM
02/08/21 06:44 PM
Good job.
I started mine by cutting a window in the bottom but it soon became obvious that wasn’t going to work due the solid construction of the plates being attached to the top.
So I grabbed my sawsall and CAREFULLY. Cut off the top. Once it was all cleaned up, and internal cables attached, I siliconed the top back on to bottom. Perfect. I mean perfect. I made a bottom (not really necessary) out of 1/4 plywood and some 1/4” bolts to serve as locating pins. The batter hold down serves its purpose of holding everything together, and secure to the tray.
Page 3 of 3 1 2 3
