498 Eagle stroker kit
#2883800
02/03/21 09:59 PM
02/03/21 09:59 PM
Posts: 114 Oklahoma City, Oklahoma
MrMayhem
Hey guys, I need some input on the Eagle brand stroker kits. I am building a 500-ish hp Eddy headed 400/498 motor for my ramcharger and saw this kit as I was shopping the various web stores. At 2k this seems very reasonably priced even though unbalanced. I know eagle has been around for fair amount of time, I just want to know if there is any reason to steer away from this kit. https://www.jegs.com/i/Eagle/356/21...PyXik-nbqDcqH8PFwvSEb5zZaa_oaMqXPRc1VpEwthanks
Re: 498 Eagle stroker kit
[Re: MrMayhem]
#2883832
02/03/21 11:13 PM
02/03/21 11:13 PM
Posts: 6,150 Melbourne , Australia
LA360
The crank and rods will need to be checked over for sizing. The Eagle stuff usually requires a touch up on their finishing/sizing.
Alan Jones
[Re: MrMayhem]
#2883872
02/04/21 03:22 AM
02/04/21 03:22 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
Everything Eagle sells for Mopar engines is made in China and listed by them as made in the U.S.A. ![work work](/ubbthreads/images/graemlins/custom/work.gif) Did you call Ohio Crankshaft Company yet for similar parts made here in the U.S.A? It not maybe you should ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) 800-333-7113 ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: earlymopar]
#2883909
02/04/21 09:31 AM
02/04/21 09:31 AM
Posts: 10,049 MN
JERICOGTX
MN
I've had a Eagle crank and rods since 2003. If I were to buy now, and I just did, I'd look at a kit through Molnar.
69 GTX
68 Road Runner
[Re: MrMayhem]
#2883922
02/04/21 10:21 AM
02/04/21 10:21 AM
Posts: 12,293 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Just out of curiosity, why would you buy an unbalanced kit?
I'll throw in another vote for Ohio Crank.
Master, again and still
[Re: DaveRS23]
#2883944
02/04/21 11:10 AM
02/04/21 11:10 AM
Posts: 143 North America
kwikblownhemi
North America
Just out of curiosity, why would you buy an unbalanced kit? Buying an expensive rotating assembly from a "reputable" builder, paying extra for balance and receiving the rods in the factory-sealed bags is a good reason. The shop I use for balancing charges the same price and actually weighs and corrects as needed.
[Re: MrMayhem]
#2883970
02/04/21 12:59 PM
02/04/21 12:59 PM
Posts: 2,009 Apollo, PA.
B1MAXX
Apollo, PA.
They (Ohio)can whip you up anything you want. B-series mains are an option. Call them, see how much one of their kits would be in b-series.
[Re: DoubleD]
#2884001
02/04/21 01:58 PM
02/04/21 01:58 PM
Posts: 3,024 NY
B1duster
NY
[Re: tubtar]
#2884006
02/04/21 02:05 PM
02/04/21 02:05 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
After the machine shop corrects everything , they aren't the bargain they appear to be. That is not saying they are junk , but like anything else , you get what you pay for. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) They're decent parts, it's just that the finish machining usually isn't very good. Don't be surprised if your brand new Eagle crank needs to be turned .010/.010 to correct it. Same goes for the rods. The ones I've seen had the caps cut tapered inward...had to be resized to fix them. Once that's done you have decent parts, but now look at the money you have tied up in them. Molnar seems to have MUCH better quality for a similar price. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: B1MAXX]
#2884029
02/04/21 02:40 PM
02/04/21 02:40 PM
Cab_Burge
[Re: kwikblownhemi]
#2884120
02/04/21 07:50 PM
02/04/21 07:50 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Just out of curiosity, why would you buy an unbalanced kit? Buying an expensive rotating assembly from a "reputable" builder, paying extra for balance and receiving the rods in the factory-sealed bags is a good reason. The shop I use for balancing charges the same price and actually weighs and corrects as needed. Frankly, I have never shopped for stroker kits by looking for the lowest price. Recommendations here and other places played a big role, along with the parts descriptions and finally, the way the salesman spoke on the phone. Some shops just didn't have time to answer the questions. Then, as long as the price was not out of line with their competitors, it becomes an easy decision. Consequently, the only companies that I have ever used have been Ohio Crank for my wedges and Ray Barton for the Hemi. I always have a local shop check it all. Everything has always checked out good. Ohio Crank even helps me calculate the comp ratio I am shooting for and machine the pistons to get there. I still have that first 499 engine that I built with an Ohio kit. It's probably 10 years old now and has had a lot of abuse including hurting it a time or two. $600 for balancing or parts in their original packaging would not fly with me, either. But I have not experienced those issues with Ohio or Barton. Knock on wood.
