498 Eagle stroker kit #2883800
02/03/21 09:59 PM
02/03/21 09:59 PM
Oklahoma City, Oklahoma
MrMayhem Offline OP
MrMayhem  Offline OP
Hey guys,
I need some input on the Eagle brand stroker kits. I am building a 500-ish hp Eddy headed 400/498 motor for my ramcharger and saw this kit as I was shopping the various web stores. At 2k this seems very reasonably priced even though unbalanced. I know eagle has been around for fair amount of time, I just want to know if there is any reason to steer away from this kit.
https://www.jegs.com/i/Eagle/356/21...PyXik-nbqDcqH8PFwvSEb5zZaa_oaMqXPRc1VpEw
thanks
Re: 498 Eagle stroker kit [Re: MrMayhem] #2883832
02/03/21 11:13 PM
02/03/21 11:13 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The crank and rods will need to be checked over for sizing. The Eagle stuff usually requires a touch up on their finishing/sizing.
Alan Jones
Re: 498 Eagle stroker kit [Re: MrMayhem] #2883872
02/04/21 03:22 AM
02/04/21 03:22 AM
Everything Eagle sells for Mopar engines is made in China and listed by them as made in the U.S.A. work
Did you call Ohio Crankshaft Company yet for similar parts made here in the U.S.A? It not maybe you should twocents 800-333-7113 scope
Re: 498 Eagle stroker kit [Re: Cab_Burge] #2883891
02/04/21 07:57 AM
02/04/21 07:57 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
A friend of mine has Eagle crank and rods with Diamond pistons in his Dodge Stratus running in the 8.50s and never had a problem with the Eagle stuff.
Re: 498 Eagle stroker kit [Re: Cab_Burge] #2883897
02/04/21 08:33 AM
02/04/21 08:33 AM
E
earlymopar Offline
earlymopar  Offline
E
As long as ANY machine work is performed in the US to allow a product to reach a "finished", sellable condition, they can legally list it the way they have.
Re: 498 Eagle stroker kit [Re: earlymopar] #2883909
02/04/21 09:31 AM
02/04/21 09:31 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I've had a Eagle crank and rods since 2003. If I were to buy now, and I just did, I'd look at a kit through Molnar.
69 GTX 68 Road Runner
Re: 498 Eagle stroker kit [Re: JERICOGTX] #2883910
02/04/21 09:43 AM
02/04/21 09:43 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
After the machine shop corrects everything , they aren't the bargain they appear to be.
That is not saying they are junk , but like anything else , you get what you pay for.
Re: 498 Eagle stroker kit [Re: MrMayhem] #2883922
02/04/21 10:21 AM
02/04/21 10:21 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Just out of curiosity, why would you buy an unbalanced kit?
I'll throw in another vote for Ohio Crank.
Master, again and still
Re: 498 Eagle stroker kit [Re: DaveRS23] #2883936
02/04/21 10:56 AM
02/04/21 10:56 AM
MrMayhem Offline OP
MrMayhem  Offline OP
My machine shop will balance for $200 verses the 600 Eagle
charges for a balanced kit
Re: 498 Eagle stroker kit [Re: MrMayhem] #2883940
02/04/21 11:04 AM
02/04/21 11:04 AM
MrMayhem Offline OP
MrMayhem  Offline OP
I just looked at the OHIO website, they dont appear to sell anything for B motor applications.....
Re: 498 Eagle stroker kit [Re: DaveRS23] #2883944
02/04/21 11:10 AM
02/04/21 11:10 AM
North America
K
kwikblownhemi Offline
K
North America
Buying an expensive rotating assembly from a "reputable" builder, paying extra for balance and receiving the rods in the factory-sealed bags is a good reason. The shop I use for balancing charges the same price and actually weighs and corrects as needed.
Re: 498 Eagle stroker kit [Re: MrMayhem] #2883948
02/04/21 11:26 AM
02/04/21 11:26 AM
Nevada
merpar Offline
merpar  Offline
Nevada
Check with 440 Source. I bought a 3.915 stroke crank and put in a 383 . It was perfect on all bearing clearances, a nice looking piece. Can't beat their prices either.
Re: 498 Eagle stroker kit [Re: merpar] #2883954
02/04/21 12:03 PM
02/04/21 12:03 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Source or Molnar
Used both with good results
Re: 498 Eagle stroker kit [Re: MrMayhem] #2883970
02/04/21 12:59 PM
02/04/21 12:59 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
They (Ohio)can whip you up anything you want. B-series mains are an option. Call them, see how much one of their kits would be in b-series.
Re: 498 Eagle stroker kit [Re: B1MAXX] #2883992
02/04/21 01:42 PM
02/04/21 01:42 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I used a Eagle Kit in a 512 it has the Mahle pistons it came balanced from Eagle - Machinist that did the block was sure it was going to be way off - had it checked it was within a gram.....I would use one of their Kits again for a budget build
Re: 498 Eagle stroker kit [Re: DoubleD] #2884001
02/04/21 01:58 PM
02/04/21 01:58 PM
NY
B1duster Offline
B1duster  Offline
NY
http://store.440source.com/Stroker-Kits/products/3/
http://www.hughesengines.com/Index/...b3cgRGVjayk=&level1=U3Ryb2tlciBLaXRz
Hughes kits are priced a little higher but use Molnar cranks and rods, with Icon pistons
and come balanced
Re: 498 Eagle stroker kit [Re: tubtar] #2884006
02/04/21 02:05 PM
02/04/21 02:05 PM
an8sec70cuda Offline
iagree They're decent parts, it's just that the finish machining usually isn't very good. Don't be surprised if your brand new Eagle crank needs to be turned .010/.010 to correct it.
Same goes for the rods. The ones I've seen had the caps cut tapered inward...had to be resized to fix them.
Once that's done you have decent parts, but now look at the money you have tied up in them.
Molnar seems to have MUCH better quality for a similar price. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 498 Eagle stroker kit [Re: B1MAXX] #2884029
02/04/21 02:40 PM
02/04/21 02:40 PM
iagree scope
I usually build my own "kits", motor parts from different vendors like Ohio Crankshaft, Molnar, Diamond, RaceTech, UEM and so on depending on the build and customers goals work up
Re: 498 Eagle stroker kit [Re: kwikblownhemi] #2884120
02/04/21 07:50 PM
02/04/21 07:50 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Frankly, I have never shopped for stroker kits by looking for the lowest price. Recommendations here and other places played a big role, along with the parts descriptions and finally, the way the salesman spoke on the phone. Some shops just didn't have time to answer the questions. Then, as long as the price was not out of line with their competitors, it becomes an easy decision. Consequently, the only companies that I have ever used have been Ohio Crank for my wedges and Ray Barton for the Hemi. I always have a local shop check it all. Everything has always checked out good. Ohio Crank even helps me calculate the comp ratio I am shooting for and machine the pistons to get there. I still have that first 499 engine that I built with an Ohio kit. It's probably 10 years old now and has had a lot of abuse including hurting it a time or two.
$600 for balancing or parts in their original packaging would not fly with me, either. But I have not experienced those issues with Ohio or Barton. Knock on wood.
Re: 498 Eagle stroker kit [Re: DaveRS23] #2884156
02/04/21 10:15 PM
02/04/21 10:15 PM
NH, USA
toddinNH Offline
Egghead
toddinNH  Offline
Egghead
NH, USA
Another voice for Tom Molnar(Molnar Technologies). Tom founded K1 many moons ago and is a good guy. You will spend a few more bucks piecing it together this way, but you'll know exactly who made ALL your stuff and be able to put a really good piston in your motor.
The reasons for choosing Molnar aren't just because he's a good guy; Molnar's stuff is made of good material and measures as well as any aftermarket company's stuff - better than almost anyone else's.
