Decent Plug Wires? #2883494
02/03/21 12:31 PM
02/03/21 12:31 PM
O
oldjonny Offline OP
Don't argue with me.
oldjonny  Offline OP
O
Have a 361 in my '66 Coronet. Have tried 3 sets of "custom" wires. All of them fit like garbage. Longest wires are WAY too long, etc. Is the general consensus just to buy make-your-own wire kits and a decent tool? Would seem like someone would make some that actually fit and for the designed routing.
Anyone?
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Decent Plug Wires? [Re: oldjonny] #2883508
02/03/21 12:59 PM
02/03/21 12:59 PM
moparx Offline
moparx  Offline
anymore, i just make my own. that way, i can run the wires in several directions to get the fit i like, then cut to the length needed.
beer
Re: Decent Plug Wires? [Re: oldjonny] #2883525
02/03/21 01:15 PM
02/03/21 01:15 PM
NJ, USA
69ACME Offline
69ACME  Offline
NJ, USA
FireCore 250's will look and fit like OEM and perform much better.
Re: Decent Plug Wires? [Re: moparx] #2883745
02/03/21 07:58 PM
02/03/21 07:58 PM
O
oldjonny Offline OP
oldjonny  Offline OP
O
beer
Whose wire kit do you buy that is worth anything? I don't want something that looks like it was out of the JC Whitney catalog.
Re: Decent Plug Wires? [Re: oldjonny] #2883750
02/03/21 08:10 PM
02/03/21 08:10 PM
Missouri
randavis Offline
randavis  Offline
Missouri
I used the Taylor 8.5 mm Spiro-Core wire kit. I bought a pair of ratchet crimpers from Summit. They make really good looking crimps.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Decent Plug Wires? [Re: moparx] #2883775
02/03/21 09:19 PM
02/03/21 09:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
iagree
We generally use the black accel spiral core 8 mm but may deviate to 7mm depending on the application twocents beer
Re: Decent Plug Wires? [Re: TJP] #2883818
02/03/21 10:34 PM
02/03/21 10:34 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Firecore! Simply the best!
I've ran MSD, and Taylor and the Firecore are head and shoulders above them. Fit perfect out of the box.
'63 Dodge 330
11.19 @ 121 mph
Re: Decent Plug Wires? [Re: TJP] #2883830
02/03/21 11:12 PM
02/03/21 11:12 PM
beer
iagree
iagree wrench up
Re: Decent Plug Wires? [Re: Cab_Burge] #2883839
02/03/21 11:34 PM
02/03/21 11:34 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Decent Plug Wires? [Re: mopars4ever] #2883890
02/04/21 07:55 AM
02/04/21 07:55 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Im running MSD wires on the Daytona. I got the ones with the adjustable angle plug boot. They came with a stripper crimper tool that works good also.
Re: Decent Plug Wires? [Re: cl440] #2883979
02/04/21 01:09 PM
02/04/21 01:09 PM
moparx Offline
moparx  Offline
lately, i have been using taylor wire sets to make my own.
beer
Re: Decent Plug Wires? [Re: moparx] #2884117
02/04/21 07:22 PM
02/04/21 07:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
When I did my 51 I used MSD Street Fire plug wires adn used my own crimping tool.
No issues
Re: Decent Plug Wires? [Re: Sniper] #2884123
02/04/21 08:02 PM
02/04/21 08:02 PM
BDW Offline
BDW  Offline
What's a decent and inexpensive crimping tool for someone who's only going to do a few sets?
Re: Decent Plug Wires? [Re: Sniper] #2884124
02/04/21 08:03 PM
02/04/21 08:03 PM
O
oldjonny Offline OP
oldjonny  Offline OP
O
Thanks for all the suggestions. Will get something on order and make my own
Re: Decent Plug Wires? [Re: BDW] #2884151
02/04/21 09:27 PM
02/04/21 09:27 PM
Missouri
randavis Offline
randavis  Offline
Missouri
I have these from Summit. https://www.summitracing.com/parts/sum-900399
They seem to do a pretty good job.
Re: Decent Plug Wires? [Re: oldjonny] #2884492
02/05/21 08:18 PM
02/05/21 08:18 PM
Florida STAYcation
dUmB! Online penguin-006
The village idiot's idiot
dUmB!  Online Penguin-006
Florida STAYcation
beer
Don’t DISS stuff from JC ! tsk
I put together a 426w in my streeter bracket racer station wagon many moons ago ! ... mid 12’s through the muffs ....
Re: Decent Plug Wires? [Re: dUmB!] #2884621
02/06/21 08:45 AM
02/06/21 08:45 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run nothing but Taylor Spiro Pros Run them on my 65 and had them on my 57 Durango the trucks etc.Las set on my hipo 65 were on like 15 years or more.Last set i bought I crimped the dist ends because I run MSD with the GM type terminals on the dist.Oh yeah we ran them with headers and mine still does.They work and last.Rocky
Chrysler Firepower
Re: Decent Plug Wires? [Re: oldjonny] #2884713
02/06/21 01:57 PM
02/06/21 01:57 PM
I've been making my own with Taylor 8MM spiral core wire with their spark plug and distributor boots and crimp on wire ends for many, many years up
They offer different colors on the wires and wire boots scope I buy the 100 ft. rolls and boots and ends in 25 count packages scope up
I use to use MSD cut to fit spark plug wire kits but not now.
Re: Decent Plug Wires? [Re: Cab_Burge] #2884724
02/06/21 02:49 PM
02/06/21 02:49 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I run Taylor’s too. Currently running PRO wires (not RF recommended) along with an MSD 6AL box and AM/FM radio with no problems!
Re: Decent Plug Wires? [Re: Cab_Burge] #2884806
02/06/21 06:16 PM
02/06/21 06:16 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
The shop I worked at years ago did tons of specialty/performance work. We built many custom wire sets using these same pieces. I built a set for my low deck A-body with CPPA headers(no way you're using a stock style set) They've been on there over 20 years...still look and work great!
