Decent Plug Wires?
#2883494
02/03/21 12:31 PM
02/03/21 12:31 PM
Posts: 5,448 Michigan
oldjonny
Don't argue with me.
Have a 361 in my '66 Coronet. Have tried 3 sets of "custom" wires. All of them fit like garbage. Longest wires are WAY too long, etc. Is the general consensus just to buy make-your-own wire kits and a decent tool? Would seem like someone would make some that actually fit and for the designed routing.
Anyone?
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Decent Plug Wires?
[Re: moparx]
#2883745
02/03/21 07:58 PM
02/03/21 07:58 PM
oldjonny
anymore, i just make my own. that way, i can run the wires in several directions to get the fit i like, then cut to the length needed. Whose wire kit do you buy that is worth anything? I don't want something that looks like it was out of the JC Whitney catalog.
[Re: oldjonny]
#2883750
02/03/21 08:10 PM
02/03/21 08:10 PM
Posts: 141 Missouri
randavis
Missouri
I used the Taylor 8.5 mm Spiro-Core wire kit. I bought a pair of ratchet crimpers from Summit. They make really good looking crimps.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: moparx]
#2883775
02/03/21 09:19 PM
02/03/21 09:19 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
[Re: TJP]
#2883818
02/03/21 10:34 PM
02/03/21 10:34 PM
Posts: 4,672 Wichita
GY3
Wichita
Firecore! Simply the best!
I've ran MSD, and Taylor and the Firecore are head and shoulders above them. Fit perfect out of the box.
[Re: TJP]
#2883830
02/03/21 11:12 PM
02/03/21 11:12 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2883839
02/03/21 11:34 PM
02/03/21 11:34 PM
Posts: 13,583 md
mopars4ever
md
[Re: Sniper]
#2884124
02/04/21 08:03 PM
02/04/21 08:03 PM
oldjonny
Thanks for all the suggestions. Will get something on order and make my own
[Re: BDW]
#2884151
02/04/21 09:27 PM
02/04/21 09:27 PM
Posts: 141 Missouri
randavis
Missouri
What's a decent and inexpensive crimping tool for someone who's only going to do a few sets? I have these from Summit. https://www.summitracing.com/parts/sum-900399They seem to do a pretty good job.
[Re: oldjonny]
#2884492
02/05/21 08:18 PM
02/05/21 08:18 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
anymore, i just make my own. that way, i can run the wires in several directions to get the fit i like, then cut to the length needed. Whose wire kit do you buy that is worth anything? I don't want something that looks like it was out of the JC Whitney catalog. Don’t DISS stuff from JC ! I put together a 426w in my streeter bracket racer station wagon many moons ago ! ... mid 12’s through the muffs ....
[Re: dOrk !]
#2884621
02/06/21 08:45 AM
02/06/21 08:45 AM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
We run nothing but Taylor Spiro Pros Run them on my 65 and had them on my 57 Durango the trucks etc.Las set on my hipo 65 were on like 15 years or more.Last set i bought I crimped the dist ends because I run MSD with the GM type terminals on the dist.Oh yeah we ran them with headers and mine still does.They work and last.Rocky
Chrysler Firepower
[Re: oldjonny]
#2884713
02/06/21 01:57 PM
02/06/21 01:57 PM
Cab_Burge
I've been making my own with Taylor 8MM spiral core wire with their spark plug and distributor boots and crimp on wire ends for many, many years They offer different colors on the wires and wire boots I buy the 100 ft. rolls and boots and ends in 25 count packages I use to use MSD cut to fit spark plug wire kits but not now.
