B-body six pack throttle cable legnth #1262422
07/05/12 09:55 PM
07/05/12 09:55 PM
MERRILLVILLE, INDIANA
sunroof446 Offline OP
Anybody know how long a 70 b-body six pack throttle cable is?
Re: B-body six pack throttle cable legnth [Re: sunroof446] #1262423
07/05/12 10:10 PM
07/05/12 10:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
This subject comes up every once in a while,....some say there is no such thing as a "sixpack" cable for the 70 B body?...I've never seen one, nor researched if one exists ....I do know the 4 bbl cable fits and works on the 70 B body with a sixpack, as I have a 440/6 in my 70 Charger...the spare 4 bbl cable I have here measures in overall length approx 16 1/2" closed, and approx 20" full open (WOT)...that's yields 3 1/2" of throttle travel
Hope this helps?
Mike
Re: B-body six pack throttle cable legnth [Re: DAYCLONA] #1262424
07/06/12 10:40 AM
07/06/12 10:40 AM
Coming up with part number 3418846 for a six pack & 2899339 for a four bbl. out of a 70 parts catalog. Must be something different.
Re: B-body six pack throttle cable legnth [Re: sunroof446] #1262425
07/06/12 12:20 PM
07/06/12 12:20 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Which '68-'70 B-body had a V8 (318, 383?) with a 2-barrel carburetor (Holley or Carter), heard that cable works..............same as going to a center 2-barrel on a 3x2 setup I was told, makes sense IMO
Re: B-body six pack throttle cable legnth [Re: sunroof446] #1262426
07/06/12 12:22 PM
07/06/12 12:22 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I don't remember the lengths anymore but I do know that the 4bbl one I bought from Mopar didn't look right and now joins the 124 other parts that I didn't use in my storage room. I ended up cleaning and lubing my original 6 pack cable.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: B-body six pack throttle cable legnth [Re: DPelletier] #1262427
07/06/12 12:29 PM
07/06/12 12:29 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
One of my Chargers is a factory 440 4 BBL car. I have had a 440 4BBL, a 440 sixpack & a dual four 426 Hemi all in this same car all using the same 440 4 BBL throttle cable with no issues.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: B-body six pack throttle cable legnth [Re: sunroof446] #1262428
07/06/12 12:29 PM
07/06/12 12:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
http://a12mopar.com/yabb/YaBB.pl?num=1249988635
Re: B-body six pack throttle cable legnth [Re: A12] #2875559
01/17/21 02:53 PM
01/17/21 02:53 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
Following
Re: B-body six pack throttle cable legnth [Re: Day2Runner] #2875747
01/17/21 09:07 PM
01/17/21 09:07 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The one on my sbird measures 20-1/2 from center of ball to center of stud hole. It measures 16-1/2" from the flat that sits against the pedal bracket, to center of stud hole closed, 18-9/16 wide open, limited by pedal bracket. It also appears to have been marked with white paint at the carb end to color code it. Only the forward barrel has the white paint, so may mean nothing. If I recall the cable body is shorter on the 4bbl cable, like 20-1/2 long with a 13-1/4 cable body.
Re: B-body six pack throttle cable legnth [Re: 4406bbl] #2882812
02/01/21 04:15 PM
02/01/21 04:15 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Just want to confirm the cable for sure has white paint on the carb end, and is date coded 316-9, car is nov 28 on the nascar list. Pretty sure it is original, and it is white paint, probably dipped before assembly, wipes off with la quar thinner, and is sticky like paint.
Re: B-body six pack throttle cable legnth [Re: 4406bbl] #2882822
02/01/21 04:39 PM
02/01/21 04:39 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I have also seen nos cables for sale that are supposed to be 1970 6bbl that have red dye stripe where mine is white, and the date code on the black cable.
