70 Charger Side Mirrors Question #2882721
02/01/21 11:40 AM
02/01/21 11:40 AM
London, England
JFChallenger440 Offline OP
London, England
Hi I have sport mirrors on my 70 Charger for some reason, see below pics ,
I want to change them to the more standard ones like in the year one links below ,
Just wondering is it a straightforward swap over ? Eg the holes will line up the same ? Also as the drivers side is a remote mirror is it difficult to get that all functional again on the new ones ? And I assume the top interior panel has to come off to remove the mirrors because currently when I unscrew the mirrors from the outside they don’t come off they only twist sideways, thanks for any help
https://www.yearone.com/Product/chrysler-b-body/mr654
https://www.yearone.com/Product/chrysler-b-body/fw834
Re: 70 Charger Side Mirrors Question [Re: JFChallenger440] #2882724
02/01/21 12:08 PM
02/01/21 12:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Racing mirrors were a mid-model year option on 1970 Chargers.
What is / are the mirror codes on your fender tag?
In addition to the screw you can see, there is a stud going down into the door top. You have to remove the interior door panel to access it.
Re: 70 Charger Side Mirrors Question [Re: Alaskan_TA] #2882769
02/01/21 02:32 PM
02/01/21 02:32 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
There are reinforcing plates you can add inside the door under the mirror.
They greatly increase the mirror's rigidity and keep the sheet metal from flexing.
Joe
Go to Mega Parts,- body -mirror reinforcements
P.S. even more important, door handle reinforcements
Re: 70 Charger Side Mirrors Question [Re: jlatessa] #2882838
02/01/21 05:24 PM
02/01/21 05:24 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
If your Charger was built after about 2/15/70 it may have been optioned with those mirrors. They would be body color. Fender tag code is G36.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 Charger Side Mirrors Question [Re: 70gtx440dana] #2882998
02/02/21 06:50 AM
02/02/21 06:50 AM
London, England
London, England
Thanks for the replies
So those year one ones should line up ok ? What about the cables ?
I would paint the current ones but it’s difficult getting in the bits where the mirrors sit
I assume it’s just the top panel on the door that needs to come off ?
Re: 70 Charger Side Mirrors Question [Re: JFChallenger440] #2883029
02/02/21 10:08 AM
02/02/21 10:08 AM
Lansing, MI
Lansing, MI
You can disassemble your current mirrors and easily paint them. You will have to take the door panels off for removal. Leave the upper pads installed.
Re: 70 Charger Side Mirrors Question [Re: 70gtx440dana] #2883049
02/02/21 11:07 AM
02/02/21 11:07 AM
London, England
London, England
Don’t you mean it’s the upper pad that has to come off ?
The lower section doesn’t give you access
Re: 70 Charger Side Mirrors Question [Re: JFChallenger440] #2883100
02/02/21 01:29 PM
02/02/21 01:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Nothing but solid steel under the upper pad, you'll need a long extension/socket to remove the nut off the stud on the mirror, your access is through the lower panel with the side window up about 1/2 way, keep the screw in the mirror base so it doesn't fall off when you remove the stud's nut
Mike
Re: 70 Charger Side Mirrors Question [Re: DAYCLONA] #2883119
02/02/21 02:26 PM
02/02/21 02:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Yup, not a big deal really.
7/16 nut, use a deep socket, long extension, 1/4" drive fits nicely.
Sometimes the stud comes out with the nut.
You might need to catch the mirror, or tape it to the body if you like.
Re: 70 Charger Side Mirrors Question [Re: topside] #2883148
02/02/21 03:28 PM
02/02/21 03:28 PM
London, England
London, England
Ok great thanks for the help
