best wrinkle paint for street hemi valve covers #2878950
01/23/21 03:04 PM
01/23/21 03:04 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Which one is it
TIA
Re: best wrinkle paint for street hemi valve covers [Re: gtx6970] #2878987
01/23/21 03:49 PM
01/23/21 03:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've used both VHT & Eastwood with xlnt results.
Main thing is to apply heat & a fair amount of the paint.
For bare metal, I first lay down some semi-flat black.
Heat gun works very well.
Re: best wrinkle paint for street hemi valve covers [Re: topside] #2879029
01/23/21 04:51 PM
01/23/21 04:51 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks,
While I have them off . I would like to repaint them . As I think the finish is way to smooth ( going thru the valves and cking valve stem seals )
Re: best wrinkle paint for street hemi valve covers [Re: gtx6970] #2879033
01/23/21 04:57 PM
01/23/21 04:57 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Thanks,
Powder coat them Bill, I have a large oven in my shop, I can do them for you here.
Re: best wrinkle paint for street hemi valve covers [Re: HEMICUDA] #2879051
01/23/21 05:28 PM
01/23/21 05:28 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
Thanks,
Bill,
I agree with Mike, Powder coat them. They come out real nice that way.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: best wrinkle paint for street hemi valve covers [Re: VCODE] #2879087
01/23/21 06:15 PM
01/23/21 06:15 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks gents.
I don't want to keep the car down that long.
I assure you I WILL have it opened back up. maybe as soon as next year for a piston swap / lower compression / repair an oil consumption issue in its future
I will re-look into powder coating them at that time
For now, I will repaint them and put them back on this week
Re: best wrinkle paint for street hemi valve covers [Re: gtx6970] #2879103
01/23/21 06:30 PM
01/23/21 06:30 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks,
I used to like the coarse finish for black wrinkle. Until you have to clean it. Then it's not so attractive.
Re: best wrinkle paint for street hemi valve covers [Re: gtx6970] #2879114
01/23/21 06:59 PM
01/23/21 06:59 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Harley used to have a wrinkle that worked real well, too. May have been made by VHT too. Who knows. I have used the Harley and the VHT. Both worked fine. The hair dryer or heat gun is a good suggestion. That way you can get as much wrinkle as you want just by adding more heat.
I have VHT on mine now. When I get the chance, I think I will look into the powder coat. The rattle can wrinkle looks okay, but it just too soft. I have pulled some flat spots in the wrinkle around the oil filler with my fingernails.
Master, again and still
Re: best wrinkle paint for street hemi valve covers [Re: DaveRS23] #2879138
01/23/21 07:44 PM
01/23/21 07:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I did my Hemi VCs 35 years ago, never a problem to clean (wasn't a leaker), still looked fresh in 2017 when I sold the car.
Silver Seal in MI had silicone valve seals in Hemi size, used them on mine and up
I think I still have some here if you need the info (bought a box of 'em).
I recall hearing the Harley wrinkle paint was good but don't recall ever using it.
Re: best wrinkle paint for street hemi valve covers [Re: topside] #2879221
01/24/21 02:46 AM
01/24/21 02:46 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks all.
Got them painted today.
they look tons better.
Also did a leak down test . 7 are between 12-15 % leak
cyl #2 is 18-19% leak.
compression ck netted all in the 200-225 range..
This is with a dead cold engine
Re: best wrinkle paint for street hemi valve covers [Re: topside] #2879239
01/24/21 09:26 AM
01/24/21 09:26 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What did you use? I coarse wrinkle finished a pair of small block covers years ago and once oil/dirt got down in the valleys of the finish, I never could get it all out. The covers always had a dungy look to them. I went for a smoother finish with later parts and cleaning was much easier.
Re: best wrinkle paint for street hemi valve covers [Re: 6PakBee] #2879304
01/24/21 12:30 PM
01/24/21 12:30 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Believe it or not, tire bleach does a super job of cleaning them. You should dilute it a good amount to prevent splotching. Then use some water based silicone to keep new dirt from sticking as well.
We use tire bleach to clean the engines on late model cars. Does a real good job.
Re: best wrinkle paint for street hemi valve covers [Re: DaveRS23] #2879325
01/24/21 12:51 PM
01/24/21 12:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
6Pak - a couple times over the years, wax & grease remover; but usually just a wipe down with a damp rag.
Simple green or just water on the rag.
For a laugh, I also wrinkled the air cleaner housing & M/T valve covers on my old restored K10.
That thing's kind of a leaker - typical SBC - and I just Simple Green the thing.
Re: best wrinkle paint for street hemi valve covers [Re: DaveRS23] #2879328
01/24/21 12:53 PM
01/24/21 12:53 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The old Underwood typewriter paint matched perfect, just had to spray a light coat of black over it
Re: best wrinkle paint for street hemi valve covers [Re: topside] #2879332
01/24/21 12:57 PM
01/24/21 12:57 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: best wrinkle paint for street hemi valve covers [Re: 6PakBee] #2879350
01/24/21 01:22 PM
01/24/21 01:22 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Running a shop or house vac with a brush tip is one way to remove dust buildup from wrinkle paint on air cleaners and valve covers. Careful to not drag the vaccume hose on you car's paint job if the parts are on the engine when you do it.
Re: best wrinkle paint for street hemi valve covers [Re: gtx6970] #2881300
01/28/21 02:26 PM
01/28/21 02:26 PM
robertop Offline
robertop  Offline
Forget about using a can, then worry about the paint thickness , and about the runs (that you will get), and using an oven, and hope for the best! Do like I did and have them powder coated with a finish that is exactly like the original and is much more resistant to scratches and to anything you do to it by handling or by accident. More expensive but definitely worth if you want to do it right the first time. And, believe me, you will have to repaint them!
Re: best wrinkle paint for street hemi valve covers [Re: robertop] #2881468
01/28/21 09:30 PM
01/28/21 09:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Nothing looks better than a Joe Dirt Hemi valve cover. Road (raced) hard and put away wet.
