best wrinkle paint for street hemi valve covers
#2878950
01/23/21 03:04 PM
01/23/21 03:04 PM
Posts: 21,427 It's a dry heat
gtx6970
It's a dry heat
Re: best wrinkle paint for street hemi valve covers
[Re: topside]
#2879029
01/23/21 04:51 PM
01/23/21 04:51 PM
gtx6970
It's a dry heat
I've used both VHT & Eastwood with xlnt results. Main thing is to apply heat & a fair amount of the paint. For bare metal, I first lay down some semi-flat black. Heat gun works very well. Thanks, While I have them off . I would like to repaint them . As I think the finish is way to smooth ( going thru the valves and cking valve stem seals )
[Re: gtx6970]
#2879033
01/23/21 04:57 PM
01/23/21 04:57 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
I've used both VHT & Eastwood with xlnt results. Main thing is to apply heat & a fair amount of the paint. For bare metal, I first lay down some semi-flat black. Heat gun works very well. Thanks, While I have them off . I would like to repaint them . As I think the finish is way to smooth ( going thru the valves and cking valve stem seals ) Powder coat them Bill, I have a large oven in my shop, I can do them for you here.
[Re: HEMICUDA]
#2879051
01/23/21 05:28 PM
01/23/21 05:28 PM
Posts: 2,377 White Plains, NY
VCODE
White Plains, NY
I've used both VHT & Eastwood with xlnt results. Main thing is to apply heat & a fair amount of the paint. For bare metal, I first lay down some semi-flat black. Heat gun works very well. Thanks, While I have them off . I would like to repaint them . As I think the finish is way to smooth ( going thru the valves and cking valve stem seals ) Powder coat them Bill, I have a large oven in my shop, I can do them for you here. Bill, I agree with Mike, Powder coat them. They come out real nice that way. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: gtx6970]
#2879103
01/23/21 06:30 PM
01/23/21 06:30 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
I've used both VHT & Eastwood with xlnt results. Main thing is to apply heat & a fair amount of the paint. For bare metal, I first lay down some semi-flat black. Heat gun works very well. Thanks, While I have them off . I would like to repaint them . As I think the finish is way to smooth ( going thru the valves and cking valve stem seals ) I used to like the coarse finish for black wrinkle. Until you have to clean it. Then it's not so attractive.
[Re: gtx6970]
#2879114
01/23/21 06:59 PM
01/23/21 06:59 PM
Posts: 12,075 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Harley used to have a wrinkle that worked real well, too. May have been made by VHT too. Who knows. I have used the Harley and the VHT. Both worked fine. The hair dryer or heat gun is a good suggestion. That way you can get as much wrinkle as you want just by adding more heat.
I have VHT on mine now. When I get the chance, I think I will look into the powder coat. The rattle can wrinkle looks okay, but it just too soft. I have pulled some flat spots in the wrinkle around the oil filler with my fingernails.
Master, again and still
[Re: DaveRS23]
#2879138
01/23/21 07:44 PM
01/23/21 07:44 PM
Posts: 20,765 A collage of whims
topside
A collage of whims
I did my Hemi VCs 35 years ago, never a problem to clean (wasn't a leaker), still looked fresh in 2017 when I sold the car. Silver Seal in MI had silicone valve seals in Hemi size, used them on mine and I think I still have some here if you need the info (bought a box of 'em). I recall hearing the Harley wrinkle paint was good but don't recall ever using it.
[Re: topside]
#2879239
01/24/21 09:26 AM
01/24/21 09:26 AM
6PakBee
North Dakota
I did my Hemi VCs 35 years ago, never a problem to clean (wasn't a leaker), still looked fresh in 2017 when I sold the car. Silver Seal in MI had silicone valve seals in Hemi size, used them on mine and I think I still have some here if you need the info (bought a box of 'em). I recall hearing the Harley wrinkle paint was good but don't recall ever using it. What did you use? I coarse wrinkle finished a pair of small block covers years ago and once oil/dirt got down in the valleys of the finish, I never could get it all out. The covers always had a dungy look to them. I went for a smoother finish with later parts and cleaning was much easier.
[Re: 6PakBee]
#2879304
01/24/21 12:30 PM
01/24/21 12:30 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Believe it or not, tire bleach does a super job of cleaning them. You should dilute it a good amount to prevent splotching. Then use some water based silicone to keep new dirt from sticking as well.
We use tire bleach to clean the engines on late model cars. Does a real good job.
[Re: DaveRS23]
#2879328
01/24/21 12:53 PM
01/24/21 12:53 PM
Posts: 8,251 fredericksburg,va
cudaman1969
fredericksburg,va
The old Underwood typewriter paint matched perfect, just had to spray a light coat of black over it
