Transmission # Tied to Engine / Car #2881190
01/28/21 08:49 AM
01/28/21 08:49 AM
E
earlymopar Offline OP
E
Looking at a 727 that was mated to a 1970 hemi and while I know the engine # is traceable back to the VIN, were transmissions in any way "numbers matching to a specific engine?
Re: Transmission # Tied to Engine / Car [Re: earlymopar] #2881206
01/28/21 10:10 AM
01/28/21 10:10 AM
A727Tflite Offline
A727Tflite  Offline
Starting in 1969 the VIN or partial VIN was stamped in the passenger side portion of the block on the pan rail and on auto transmissions on the passenger side portion of the bell on a raised hump.
In 68 the partial VIN was stamped on the top of the block and trans at the bellhousing area on some cars.
I’m sure others will pipe in .......
Edited - thanks Rhinodart
Re: Transmission # Tied to Engine / Car [Re: A727Tflite] #2881217
01/28/21 10:35 AM
01/28/21 10:35 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
In 69 the partial VIN was stamped on the top of the block and trans at the bellhousing area on some cars.
Yes, you are correct on the first sentence, the second one you should have said 68. To the OP, your trans will have a stamp on the passenger side and on the drivers side pan rail will be the exact part number of the trans to make sure it is at least the proper application.
JB Rhinehart, Realist
A-Body's RULE!
Re: Transmission # Tied to Engine / Car [Re: Rhinodart] #2881268
01/28/21 01:28 PM
01/28/21 01:28 PM
NW New Jersey
RSI700VIPER Offline
RSI700VIPER  Offline
NW New Jersey
To add to Rhino's response, the transmission and engine are stamped with the car's VIN at the exact same moment using the same tool by the same line worker ... WHACK! WHACK! So if the 9 in the VIN is crooked or deeper on the engine, so it will be on the trans.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Transmission # Tied to Engine / Car [Re: RSI700VIPER] #2881274
01/28/21 01:50 PM
01/28/21 01:50 PM
NW New Jersey
RSI700VIPER Offline
RSI700VIPER  Offline
NW New Jersey
Here in an example from one of my cars. Notice the "E" and "1" and even "0" (on one side) of both stampings are not as deep at the other numbers and letter.
Re: Transmission # Tied to Engine / Car [Re: RSI700VIPER] #2881278
01/28/21 01:54 PM
01/28/21 01:54 PM
E
E
Thanks guys. This is all very helpful. I took a couple of pictures yesterday, one of which has a number but it was on the driver's side. The other picture I just opened up and zoomed-in and see what looks like another number that I might have missed.
Attached PDF document
Number Location.pdf (32 downloads)
Re: Transmission # Tied to Engine / Car [Re: RSI700VIPER] #2881288
01/28/21 02:04 PM
01/28/21 02:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's been said that the numbers were stamped with a pneumatic "gun" with changeable numbers, much like a date stamp. The operator's grip and positioning of the gun account for the varying quality of the stamps.
Re: Transmission # Tied to Engine / Car [Re: John_Kunkel] #2881304
01/28/21 02:33 PM
01/28/21 02:33 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
What are the part number stampings on the drivers side at the pan rail on the 69 trans?
Matt
Re: Transmission # Tied to Engine / Car [Re: earlymopar] #2881803
01/29/21 06:11 PM
01/29/21 06:11 PM
E
E
Well, I found this same number on the bell housing area of the passenger side.
Re: Transmission # Tied to Engine / Car [Re: earlymopar] #2881889
01/29/21 10:23 PM
01/29/21 10:23 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
both of the pics posted in this thread are of the same partial VIN stamping on a 727 automatic transmission
what is the part number on the driver's side?
the partial VIN - 9G244992 is from a 1969 Dodge or Plymouth B-body built at the St, Louis assembly plant
Re: Transmission # Tied to Engine / Car [Re: 6bblgt] #2881892
01/29/21 10:33 PM
01/29/21 10:33 PM
BDW Offline
BDW  Offline
Is it just me, or does that last 9 look out of place, much larger than the others?
Re: Transmission # Tied to Engine / Car [Re: earlymopar] #2881932
01/30/21 01:24 AM
01/30/21 01:24 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
a 1970 Hemi transmission will be stamped on the drivers side pan rail PK3410671. then you'll know it's an original HEMI transmission
Re: Transmission # Tied to Engine / Car [Re: 1965_PLYMOUTH] #2881959
01/30/21 09:11 AM
01/30/21 09:11 AM
E
E
Thanks guys. I've found the same number on both sides of the transmission and in both cases the 9 is larger than the other numbers. So far, I've found nothing on the pan rail on either side. I'm guessing since the transmission was painted by the person that race-prepped it, the paint filled-in an already shallow stamped number. I'll go back today with some scotchbrite or sand paper to remove the paint.
Re: Transmission # Tied to Engine / Car [Re: earlymopar] #2882098
01/30/21 04:57 PM
01/30/21 04:57 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
the 2 pictures you posted are of the same VIN stamping on the passenger side - the PK# & assembly date info will be stamped on the driver's side pan rail
there are no other factory stampings on a 727 transmission case
the partial VIN will point to a specific car - it is probably from a Charger, but I do not have enough info to claim that 100% - is it a 383, 440 or HEMI unit? - you need the PK # to identify the case beer
9g244992-trans 727-VIN.jpgmoparts PK2801544J 2251 862-HEMI TRANS.jpgmoparts PK2892094L 2588 0829.JPG
Re: Transmission # Tied to Engine / Car [Re: 6bblgt] #2882288
01/31/21 08:43 AM
01/31/21 08:43 AM
E
E
Thanks for noting the same pictures were used. You're sure right. My wife sent these to me from her phone. I didn't get to the storage unit yesterday but plan to go today to look further for the numbers along the rail
Re: Transmission # Tied to Engine / Car [Re: earlymopar] #2882378
01/31/21 01:43 PM
01/31/21 01:43 PM
E
E
Here is the #. Once I got it in better light and wiped it off, it's pretty clear
Re: Transmission # Tied to Engine / Car [Re: earlymopar] #2882453
01/31/21 03:53 PM
01/31/21 03:53 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
PK2892093L 2793 4134
PK = Kokomo, IN transmission plant
2892093 = 727 for 383 4bbl, 383HP & 440HP
L = ??
2793 = Friday March 21, 1969 transmission assembly date
4134 = transmission unit number
Re: Transmission # Tied to Engine / Car [Re: 6bblgt] #2882481
01/31/21 05:02 PM
01/31/21 05:02 PM
E
E
Thanks 6BBL and everyone else that helped and directed me. I found enough on decoding the number to figure out most of it except the date code which I haven't seen an explanation of. So thanks for getting that number decoded.
Just curious, what were the actual differences between a 727 used in a production 440 versus a 727 mated to a hemi? This transmission was actually behind a hemi (and forward of a Dana 60) in a 1969 B-body bracket race car. The transmission has a sticker on it from a well known Oregonian Mopar enthusiast who was a drag racer and who was also involved in selling Mopar parts and service. So, I assume it has a shift kit at a minimum and an aftermarket converter with higher stall speed.
Re: Transmission # Tied to Engine / Car [Re: earlymopar] #2882554
01/31/21 08:06 PM
01/31/21 08:06 PM
NW New Jersey
RSI700VIPER Offline
RSI700VIPER  Offline
NW New Jersey
I'm curious too. I understand there were significant upgrades to a hemi trans. I have a 1971 hemi trans. Were all 727 hemi transmissions the same internally year to year?
Re: Transmission # Tied to Engine / Car [Re: RSI700VIPER] #2882696
02/01/21 08:56 AM
02/01/21 08:56 AM
E
E
Hopefully someone here can educate us on this issue. I had this question before but with this transmission it has come up again.
