Re: Transmission # Tied to Engine / Car
[Re: earlymopar]
#2881206
01/28/21 10:10 AM
01/28/21 10:10 AM
Posts: 3,076 Michigan
A727Tflite
Starting in 1969 the VIN or partial VIN was stamped in the passenger side portion of the block on the pan rail and on auto transmissions on the passenger side portion of the bell on a raised hump.
In 68 the partial VIN was stamped on the top of the block and trans at the bellhousing area on some cars.
I’m sure others will pipe in .......
Edited - thanks Rhinodart
[Re: A727Tflite]
#2881217
01/28/21 10:35 AM
01/28/21 10:35 AM
Posts: 43,547 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
In 69 the partial VIN was stamped on the top of the block and trans at the bellhousing area on some cars.
I’m sure others will pipe in ....... Yes, you are correct on the first sentence, the second one you should have said 68. To the OP, your trans will have a stamp on the passenger side and on the drivers side pan rail will be the exact part number of the trans to make sure it is at least the proper application.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2881268
01/28/21 01:28 PM
01/28/21 01:28 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
I’m sure others will pipe in ....... Yes, you are correct on the first sentence, the second one you should have said 68. To the OP, your trans will have a stamp on the passenger side and on the drivers side pan rail will be the exact part number of the trans to make sure it is at least the proper application. To add to Rhino's response, the transmission and engine are stamped with the car's VIN at the exact same moment using the same tool by the same line worker ... WHACK! WHACK! So if the 9 in the VIN is crooked or deeper on the engine, so it will be on the trans.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
[Re: RSI700VIPER]
#2881274
01/28/21 01:50 PM
01/28/21 01:50 PM
RSI700VIPER
NW New Jersey
Here in an example from one of my cars. Notice the "E" and "1" and even "0" (on one side) of both stampings are not as deep at the other numbers and letter.
[Re: RSI700VIPER]
#2881278
01/28/21 01:54 PM
01/28/21 01:54 PM
Posts: 1,335 Oregon
earlymopar
Thanks guys. This is all very helpful. I took a couple of pictures yesterday, one of which has a number but it was on the driver's side. The other picture I just opened up and zoomed-in and see what looks like another number that I might have missed.
[Re: RSI700VIPER]
#2881288
01/28/21 02:04 PM
01/28/21 02:04 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's been said that the numbers were stamped with a pneumatic "gun" with changeable numbers, much like a date stamp. The operator's grip and positioning of the gun account for the varying quality of the stamps.
[Re: earlymopar]
#2882098
01/30/21 04:57 PM
01/30/21 04:57 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
the 2 pictures you posted are of the same VIN stamping on the passenger side - the PK# & assembly date info will be stamped on the driver's side pan rail there are no other factory stampings on a 727 transmission case the partial VIN will point to a specific car - it is probably from a Charger, but I do not have enough info to claim that 100% - is it a 383, 440 or HEMI unit? - you need the PK # to identify the case
[Re: earlymopar]
#2882554
01/31/21 08:06 PM
01/31/21 08:06 PM
RSI700VIPER
NW New Jersey
Just curious, what were the actual differences between a 727 used in a production 440 versus a 727 mated to a hemi? I'm curious too. I understand there were significant upgrades to a hemi trans. I have a 1971 hemi trans. Were all 727 hemi transmissions the same internally year to year?
