solid roller lifter choices 700hp #2879550
01/24/21 07:05 PM
01/24/21 07:05 PM
portland, ct
Since1822 Offline OP
portland, ct
Looking for input on what everyone is running for solid roller lifters.
493' 11.5 to 1 trick flow 270 head
super victor intake with dominator
269/276 690ish cam
race car little to no street time
bushed lifter bores
BAM, Crower, Comp, Isky red??
Re: solid roller lifter choices 700hp [Re: Since1822] #2879627
01/24/21 09:45 PM
01/24/21 09:45 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have had good luck with the comp 829-16 , but at higher psi have been using the morels . I always buy vavletrain parts from Scott at buy racing parts.com
....BAD A$$ STREET CAR.....
Re: solid roller lifter choices 700hp [Re: Since1822] #2879660
01/24/21 10:30 PM
01/24/21 10:30 PM
Crower Ultra .904 with pushrod oiling installed with 325 Lbs. on the seats with around 840 Lbs. over the nose shifting at 7000 to 7500 RPM with .730 net lift up twocents
No measurable wear on any of the valve train parts(Jesel 1.55 ratio paired shaft rocker arms on a set of Indy 440-1 heads and Manton series 5 custom oil though pushrods) since setting the lash hot after one race with 9 1/8 mile passes, 60 runs since with 15 1/4 mile runs and the rest 1/8 miles up
Re: solid roller lifter choices 700hp [Re: Cab_Burge] #2879751
01/25/21 09:35 AM
01/25/21 09:35 AM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by Cab_Burge
Crower Ultra .904 with pushrod oiling ...
Looks like these from your description. Link to Summit listing
~$850 /set
Or is it the version without the "H" in the part number? That listing ~$700, still says pushrod oiling, but not pressurized roller.
Do you have a picture of the actual lifter showing where the oil band is located? Many web listing pictures are just "representative" not actual.
Quote
Manufacturer's Part Number:66233H-16
Product Line:Crower Severe-Duty Roller Lifters
Link Bar Type:Vertical
Lifter Outside Diameter (in):0.903 in.
Lifter Offset:None
Quantity:Sold as a set of 16.
Notes:With pushrod oiling and Hi Pressure Pin Oiling (HIPPO) option.
Re: solid roller lifter choices 700hp [Re: 440Jim] #2879888
01/25/21 02:10 PM
01/25/21 02:10 PM
No pictures of them, there in my motor.
Re: solid roller lifter choices 700hp [Re: Cab_Burge] #2880284
01/26/21 08:10 AM
01/26/21 08:10 AM
pa
572charger Offline
572charger  Offline
pa
ive been using 829 comps for 20 years i just change them out every 3 years
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: solid roller lifter choices 700hp [Re: Since1822] #2880591
01/26/21 07:24 PM
01/26/21 07:24 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
BAM has a solid roller lifter that is pushrod oiled, direct oiled and a steel bushing instead of the bronze. They tell me it lasts 3 times longer than the bronze. About $1100.
Re: solid roller lifter choices 700hp [Re: 572charger] #2880592
01/26/21 07:25 PM
01/26/21 07:25 PM
NC
440Jim Offline
440Jim  Offline
NC
How many passes down the track?
What spring pressures are you running?
What is the shift rpm?
Re: solid roller lifter choices 700hp [Re: 440Jim] #2880608
01/26/21 07:49 PM
01/26/21 07:49 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I had terrible luck with the Comp 829 lifter in a streeter. I have the Comp 848 AMC spec lifter with hippo oiling for 10 years with 1 rebuild.@ 5 years,,, Went 7/10k miles with maybe 20 passes a year before being rebuilt.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: solid roller lifter choices 700hp [Re: mopar dave] #2880642
01/26/21 08:41 PM
01/26/21 08:41 PM
portland, ct
portland, ct
Thanks, they are what dwayne recommended running and is what I will be going with. Expensive yes, but have heard good things about them.
Re: solid roller lifter choices 700hp [Re: Since1822] #2881911
01/29/21 11:50 PM
01/29/21 11:50 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I have a build very similar to yours. I used a Howard’s roller lifter that oils the roller bearing. I’ll see if I can find the part #.
