3spd transmission #2880084
01/25/21 07:06 PM
01/25/21 07:06 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Does anyone on here own a car with a 3spd manual transmission? I have a 70 cuda convertible with a three speed . The problem is it sounds like an old army Jeep in first gear. As soon as you go to second gear the noise is gone. My guess it’s the way the gear is cut and unfortunately normal. Just looking for anyone who can confirm this.
Re: 3spd transmission [Re: 340swing] #2880092
01/25/21 07:20 PM
01/25/21 07:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That is not normal with an A-230 3-speed.
I drive mine as often as possible and it does not do that at all.
Re: 3spd transmission [Re: 340swing] #2880094
01/25/21 07:24 PM
01/25/21 07:24 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I owned a 71 RR 383 3spd.& first gear sounded like the other 2 normal, my guess is you have a bearing problem going on.
Re: 3spd transmission [Re: 71GTX471] #2880106
01/25/21 07:55 PM
01/25/21 07:55 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Any idea if parts are available for a 3spd brewers has a very limited selection on their website
Re: 3spd transmission [Re: 340swing] #2880128
01/25/21 08:34 PM
01/25/21 08:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 3spd transmission [Re: Alaskan_TA] #2880149
01/25/21 09:11 PM
01/25/21 09:11 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Thanks I will check it out
Re: 3spd transmission [Re: 340swing] #2880267
01/26/21 03:16 AM
01/26/21 03:16 AM
you have a PM on this scope
Re: 3spd transmission [Re: 340swing] #2880420
01/26/21 02:05 PM
01/26/21 02:05 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I have 2 or 3 of them laying around that I would sell real cheap. If not, have you considered swapping in an overdrive 4-speed? I have swapped in both O/D’s and standard 4- speeds. Easy swap. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: 3spd transmission [Re: BANDIT] #2880432
01/26/21 02:40 PM
01/26/21 02:40 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
If it is a 383 Cuda three speed- then this A230 is a close ratio, big bearing version. It is not all the same internals as an A230 from an LA or /6. The noise mentioned is likely a bearing or from the coutnershaft/needle bearing area. These items should be procurable.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 3spd transmission [Re: EWJ] #2880439
01/26/21 02:54 PM
01/26/21 02:54 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I’d have to double check, but one of them was out of a 71 RoadRunner, 383 car that I had swapped a 4-speed into. The others, I can’t remember anymore. But yes, I’m sure Zumbrota, or someplace like that, would have parts. Jim.
4600 DA
Re: 3spd transmission [Re: BANDIT] #2880488
01/26/21 04:12 PM
01/26/21 04:12 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Barry, can you text me at 406-489-3534, my phone will not reply to your email. Jim.
4600 DA
Re: 3spd transmission [Re: 340swing] #2880500
01/26/21 04:37 PM
01/26/21 04:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Hard parts for the A230 are getting scarce, overhaul kits are easy to find but the only place I've found gears is on E-bay.
Re: 3spd transmission [Re: BANDIT] #2880511
01/26/21 04:51 PM
01/26/21 04:51 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The only way I can send text is via my PC.
I do everything via letter or email, no phone.
Re: 3spd transmission [Re: Alaskan_TA] #2880611
01/26/21 07:55 PM
01/26/21 07:55 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
My car is a 340 numbers matching original trans. I will get it apart and let you know what I find.
