Page 2 of 3 1 2 3
Re: What does NOT RECOMMENDED mean ... ? [Re: dOrk !] #2877137
01/20/21 12:05 PM
01/20/21 12:05 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
Originally Posted by Doc Fiberglass
Last line ... I can understand the HellKitty combo ..,,but the others ??
Wonder what changed from 2018...
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: What does NOT RECOMMENDED mean ... ? [Re: 300rag] #2877140
01/20/21 12:09 PM
01/20/21 12:09 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
2 choices:
- follow the recommendation and don't tow with it
- tow with it anyway, and prepare to accept the consequences should something go wrong
Earning every penny of that moderator paycheck.
DBAP
Re: What does NOT RECOMMENDED mean ... ? [Re: not_a_charger] #2877160
01/20/21 12:30 PM
01/20/21 12:30 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I'm thinking something other than drivetrain itself. Ride height?
Facts are stubborn things.
Re: What does NOT RECOMMENDED mean ... ? [Re: larrymopar360] #2877169
01/20/21 12:40 PM
01/20/21 12:40 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Maybe the excess heat from turbo/supercharger equipped engines
running above the designed RPMs to road speed was their caution??
Joe
Edit Also, turbos under a constant load is tough on those not designed for that
type of use.
Re: What does NOT RECOMMENDED mean ... ? [Re: jlatessa] #2877283
01/20/21 02:24 PM
01/20/21 02:24 PM
moparx Offline
moparx  Offline
HaY DoC ! i'll hold yer BeEr and WaTcH ! ............... biggrin
beer
Re: What does NOT RECOMMENDED mean ... ? [Re: moparx] #2877325
01/20/21 03:09 PM
01/20/21 03:09 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
This, would you use your jet boat in place of a tug boat.... no.
STOP POTATO HATE!
Re: What does NOT RECOMMENDED mean ... ? [Re: Mr PotatoHead] #2877337
01/20/21 03:19 PM
01/20/21 03:19 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Great. NOW you tell me. I've been doing this for years.
Re: What does NOT RECOMMENDED mean ... ? [Re: Mr PotatoHead] #2877340
01/20/21 03:21 PM
01/20/21 03:21 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Doc, maybe its not the car that cannot handle it, maybe it the trailer cannot handle all the Mopar horse power? whistling drive
More than likely it has to due the components in the car, the trucks have the same size motors and you can tow with them.
My Monster are real!
Living within your means makes life pretty easy.
Re: What does NOT RECOMMENDED mean ... ? [Re: 67vertman] #2877528
01/20/21 08:50 PM
01/20/21 08:50 PM
Florida STAYcation
dOrk ! Offline OP
The village idiot's idiot
dOrk !  Offline OP
Florida STAYcation
Man ... do I need some catchin up to do !
I’ll bbl ... xmaseek
Re: What does NOT RECOMMENDED mean ... ? [Re: dOrk !] #2877591
01/20/21 11:10 PM
01/20/21 11:10 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
As I read it, it specifically reads "on supercharged vehicles".
Back in the 90s, Dodge did the same thing with the turbocharged cars, limited the towing capacity. The thought process back then was the forced induction puts extreme loads on drive line and drive train parts and towing would only increase that already high load.
Imagine a 6.4 supercharged Challenger leaving a stop light, pulling a steep hill, in the rain, probably a white knuckle ride. Now picture that same car at the same traffic light, looking at the same hill, in the rain, but now has to get 5,000 extra lbs to move that is hanging on the back bumper. The 1st event eliminated 75% of the "new" hellcat owners. The second event eliminated all but about the top 5%, and those guys are not going to hang a trailer hitch on their Hellcat, and probably wouldn't be driving in the rain.
Do the same deal except instead of rain, you add a 90 degree day in July, how long do you think that trans is going to last? The trans may do the actual towing just fine, the problem will come 20,000 miles down the road when those burnt up clutches in the trans show up. Got a trailer hitch, yep, your problem, not theirs. The car companies are covering their butts. Gene
Re: What does NOT RECOMMENDED mean ... ? [Re: poorboy] #2877691
01/21/21 07:30 AM
01/21/21 07:30 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Note that the SRT Durango and SRT Jeep Cherokee, and TrackHawk Grand Cherokee all have towing ratings. Motor Trend even tested the new ram TRX 0-60 pulling a 24' airstream trailer(6.8 seconds BTW).
I don't believe its the drivetrain at all, its the fact that if you hammered it from a stoplight with any significant weight hooked to a hitch it would probably rip it from the unibody ofd the LX cars.
68 Barracuda Formula S 340
Re: What does NOT RECOMMENDED mean ... ? [Re: Bad340fish] #2877941
01/21/21 04:16 PM
01/21/21 04:16 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I don't know anything about those cars but a few possibilities come to mind.
Do the hemi cars have a rear facia that hangs to low to clear a hitch?
Does the exhaust system on a hemi car get in the way of mounting an adequate hitch?
Will the wider tires on a hemi car rub if the back of the car sags from too much weight?
Re: What does NOT RECOMMENDED mean ... ? [Re: not_a_charger] #2878754
01/23/21 07:28 AM
01/23/21 07:28 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Originally Posted by not_a_charger
2 choices:
iagree There's a guy on hellcat.org that has a hitch on his Charger and has no issues. I questioned whether having that trailer back there and no tow package with a button to turn off rear sensors that it would be beeping everytime you turn. He said no issue. shruggy
Re: What does NOT RECOMMENDED mean ... ? [Re: not_a_charger] #2879172
01/23/21 09:37 PM
01/23/21 09:37 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted by Bad340fish
They obviously have some concerns, maybe its a stability thing if the owner has the power to go to fast with a trailer?
They rate the hellcat and 6.4 powered grand cherokees for towing decent amounts so its not a drivetrain thing most likely. Its likely a legal deal covering their ass because something about that combo is less than ideal for towing.
That, and they will look to deny warranty coverage for anything mechanical that goes wrong if they can show that you towed with it.
I can tow all of them,,,,,2 atta time. Use the caRRoT VaN to ToE...... whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What does NOT RECOMMENDED mean ... ? [Re: hemi-itis] #2879227
01/24/21 06:20 AM
01/24/21 06:20 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Probably got more to do with compression and cylinder pressure than anything else / DETONATION !
Re: What does NOT RECOMMENDED mean ... ? [Re: dOrk !] #2879372
01/24/21 02:16 PM
01/24/21 02:16 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
"What does NOT RECOMMENDED mean....?"
When I see this statement, my instinctive reaction is: It's probably fine, unless you're a moron.
Remember, manufactures have to protect themselves from anyone that purchases the product.
I can easily see a manufacturer, and its lawyers, concluding that it's not a good idea to build a hot rod/performance car without the words "not recommend" when it comes to towing because of how Joe Q public might tow with it.
If there was a "real" problem with towing with it, they would use language different than "not recommended".
Re: What does NOT RECOMMENDED mean ... ? [Re: BSB67] #2879719
01/25/21 01:04 AM
01/25/21 01:04 AM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
Day..... ummmmm ... where do I start ? I’ll get to it ! ... thx fur the input
Re: What does NOT RECOMMENDED mean ... ? [Re: Mcode69] #2879744
01/25/21 08:48 AM
01/25/21 08:48 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The same engine in the Grand Cherokee or Durango (the 6.4L) is rated to tow. Even the HellCat engine is rated to tow in other platforms.
Re: What does NOT RECOMMENDED mean ... ? [Re: Bad340fish] #2880385
01/26/21 12:47 PM
01/26/21 12:47 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
shruggy
STOP POTATO HATE!
Re: What does NOT RECOMMENDED mean ... ? [Re: Mr PotatoHead] #2880725
01/27/21 12:20 AM
01/27/21 12:20 AM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
A friend has been telling me of this rigged up kitty..... hea ya go Doc, get yous a big ole hitch and a pushbar for when the brakes fail. up
Friend says this owner is wealthy and does as he wants weather rational or not.
STOP POTATO HATE!
Page 2 of 3 1 2 3
