Anybody else ever heard of this nonsense #2879863
01/25/21 01:34 PM
01/25/21 01:34 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Was on another forum.
Guy buys a crate motor and cant get it to run cool. Has thrown a new radiator at it, ect. No change.
So he calls the company and they tell him, no problem, common issue, it will cool down 30 degrees once its “ broken in”
Lol
Trying to think of anything i have ever had that tan any cooler the next week, next month, next year.
Being in the car business, i have driven literally thousands of brand new cars, cant remember any that didn't run cool initially, that didn't have to “ break in” to run cool.
They probably figure he will throw enough parts at it to fix the issue before its broken in.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2879866
01/25/21 01:38 PM
01/25/21 01:38 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
It can be true with a complete rebuild that it might run warmer on the first few startups while it does "break in" but not 30 degrees. Especially a stock type motor should not be running "hot" like that. Make sure to burp it good but I would not continue to keep running it until I identified the reason.
Todd
Re: Anybody else ever heard of this nonsense [Re: sasquatch] #2879869
01/25/21 01:45 PM
01/25/21 01:45 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Todd
Right. This guy was told it was normal for the first 500 miles. Crazy.....
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2879896
01/25/21 02:19 PM
01/25/21 02:19 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
500 miles at a 1/4 mile at a time could take years. LOL I would say either the engine is too tight or something in the cooling system is partially blocked. Does the owner have one of those digital thermometers ? If so I would read it all over the engine and find the hot spots
6.50 @105.26
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2879933
01/25/21 02:54 PM
01/25/21 02:54 PM
Boise
Moparteacher Offline
Boise
Complete nonsense. Either the new owner is doing something wrong i.e., air trapped in the cooling system, timing, lean, wp flow direction etc. Or, there's a problem with the new engine. Head gasket(s) on backwards, blockage in the cooling passages, cylinder walls are too thin, engine is too tight (and I have doubts about that issue),,
Or, it's not running hot at all and there's a fault in the temp sender or gauge.
But running hot until broke-in is bs, slightly warmer...maybe, but noticeably hotter? Nope.
Re: Anybody else ever heard of this nonsense [Re: Kindafast] #2879936
01/25/21 02:55 PM
01/25/21 02:55 PM
moparx Offline
moparx  Offline
Originally Posted by Kindafast
500 miles at a 1/4 mile at a time could take years. LOL I would say either the engine is TOO TIGHT or SOMETHING in the COOLING SYSTEM is partially blocked. Does the owner have one of those digital thermometers ? If so I would read it all over the engine and find the hot spots
this ! ^^^^^^^^^^^^^ iagree
beer
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2879973
01/25/21 03:41 PM
01/25/21 03:41 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Lol
LMAO..... did they tell him take the rad cap off and let it run until it "burped" ??? Maybe they figure he just has air trapped and eventually its going to come out ??
....BAD A$$ STREET CAR.....
Re: Anybody else ever heard of this nonsense [Re: n20mstr] #2880044
01/25/21 05:51 PM
01/25/21 05:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Makes zero sense for sure but it got him off the phone. Id suggest he checks his ignition timing and maybe even ad a few degress. Seen many engine run hot from not enough initial timing..But the why is a whole other story.
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2880077
01/25/21 06:56 PM
01/25/21 06:56 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Too warm in January? It's really gonna suck this summer. "Broken in" or not.
Master, again and still
Re: Anybody else ever heard of this nonsense [Re: Al_Alguire] #2880147
01/25/21 09:09 PM
01/25/21 09:09 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Yea, he is driving it now(408 stroker) and its staying around 190 with it 40 degrees out he says. Hopes it will be “ broken in “ by summer time. Not sure where he lives
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2880158
01/25/21 09:20 PM
01/25/21 09:20 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
190 degrees is NOT hot even at 40 degrees outside. There are a lot of unanswered questions here.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2880162
01/25/21 09:28 PM
01/25/21 09:28 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
The guy is an idiot. You DiD tell him he’s an idiot right? If you didn’t.....why not? Seriously?
Re: Anybody else ever heard of this nonsense [Re: fourgearsavoy] #2880179
01/25/21 10:03 PM
01/25/21 10:03 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Gus beer
When it was 85 out the guy said it ran 215. Believe he stopped driving it after swapping in a radiator and it staying at that temp.
Then he lets it sit and tries it again when its 40 out and it runs 190.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2880203
01/25/21 10:38 PM
01/25/21 10:38 PM
It seems he doesn't know how to fix it or find out what is causing the heating problems, he should take it to a good shop and get them to tell them what it needs or have them fix it twocents
Re: Anybody else ever heard of this nonsense [Re: Cab_Burge] #2880239
01/25/21 11:39 PM
01/25/21 11:39 PM
NY
B1duster Offline
B1duster  Offline
NY
The guy on the phone is either just a salesman or he BS’d, or both.
Is it actually boiling over ? is the gauge accurate ? Water pump ok ? Running lean ? timing ?
Re: Anybody else ever heard of this nonsense [Re: B1duster] #2880289
01/26/21 08:29 AM
01/26/21 08:29 AM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
is their a thermostat in it?I have seen cars run hotter without a thermostat,too fast flow.
Re: Anybody else ever heard of this nonsense [Re: GarageDodge] #2880306
01/26/21 09:44 AM
01/26/21 09:44 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
This is the post by the owner of the new motorthat got me
“So it turns out that blueprint engines run hotter during break-in. I got ahold of a service guy there, and he said 210-220 is what the typically what they run during break in, and after about 500-1000 miles should slowly come down to 180 degrees. I do see the posts talking about that my timing is not advanced enough, I could maybe put lighter springs in so the full advance kicks in a lot sooner than 4000, but I can’t make it go past 34 degrees. That’s the max blueprint recommends.”
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2880319
01/26/21 10:18 AM
01/26/21 10:18 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
After checking all the usual suspects such as cooling system problems,timing and guage accuracy look at the spark plugs or co2 reading to see if a lean fuel condition is the culprit.Many times lean fuel and to much timing will cause an engine to run hot.Also make sure you run a thermostat or restrictor(usually a 5/8 hole) to allow the coolant to pass through the rad slow enough to be cooled.Don't realy on the engine supplier's opinion unless they have actually investigated all the circumstances.All the possible issues mentioned should be checked and eliminated.
Re: Anybody else ever heard of this nonsense [Re: B3422W5] #2880321
01/26/21 10:20 AM
01/26/21 10:20 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Might need the curve shortened. It could have 0° at idle.
Re: Anybody else ever heard of this nonsense [Re: B G Racing] #2880324
01/26/21 10:26 AM
01/26/21 10:26 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
The point is, the company that built the engine said it was typical for them to run 30 degrees cooler 500-1000 miles down the road after they are “ broken in”
I take that at face value. No mention of..did you do this or that
1.41 best 60 foot
6.60 at 103.90 1/8
