Re: 3spd transmission
[Re: 340swing]
#2880420
01/26/21 02:05 PM
01/26/21 02:05 PM
Posts: 422 montana
BANDIT
montana
I have 2 or 3 of them laying around that I would sell real cheap. If not, have you considered swapping in an overdrive 4-speed? I have swapped in both O/D’s and standard 4- speeds. Easy swap. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2880432
01/26/21 02:40 PM
01/26/21 02:40 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
If it is a 383 Cuda three speed- then this A230 is a close ratio, big bearing version. It is not all the same internals as an A230 from an LA or /6. The noise mentioned is likely a bearing or from the coutnershaft/needle bearing area. These items should be procurable.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: EWJ]
#2880439
01/26/21 02:54 PM
01/26/21 02:54 PM
Posts: 422 montana
BANDIT
montana
I’d have to double check, but one of them was out of a 71 RoadRunner, 383 car that I had swapped a 4-speed into. The others, I can’t remember anymore. But yes, I’m sure Zumbrota, or someplace like that, would have parts. Jim.
[Re: BANDIT]
#2880488
01/26/21 04:12 PM
01/26/21 04:12 PM
Posts: 422 montana
BANDIT
montana
Barry, can you text me at 406-489-3534, my phone will not reply to your email. Jim.
[Re: 340swing]
#2880500
01/26/21 04:37 PM
01/26/21 04:37 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Hard parts for the A230 are getting scarce, overhaul kits are easy to find but the only place I've found gears is on E-bay.
