Re: solid roller lifter choices 700hp
[Re: Since1822]
#2879627
01/24/21 09:45 PM
01/24/21 09:45 PM
Posts: 4,696 On the parachute mount
n20mstr
I have had good luck with the comp 829-16 , but at higher psi have been using the morels . I always buy vavletrain parts from Scott at buy racing parts.com
....BAD A$$ STREET CAR.....
[Re: Since1822]
#2879660
01/24/21 10:30 PM
01/24/21 10:30 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
Crower Ultra .904 with pushrod oiling installed with 325 Lbs. on the seats with around 840 Lbs. over the nose shifting at 7000 to 7500 RPM with .730 net lift No measurable wear on any of the valve train parts(Jesel 1.55 ratio paired shaft rocker arms on a set of Indy 440-1 heads and Manton series 5 custom oil though pushrods) since setting the lash hot after one race with 9 1/8 mile passes, 60 runs since with 15 1/4 mile runs and the rest 1/8 miles
[Re: Cab_Burge]
#2879751
01/25/21 09:35 AM
01/25/21 09:35 AM
Posts: 16,930 NC
440Jim
NC
Crower Ultra .904 with pushrod oiling ... Looks like these from your description. Link to Summit listing~$850 /set Or is it the version without the "H" in the part number? That listing ~$700, still says pushrod oiling, but not pressurized roller. Do you have a picture of the actual lifter showing where the oil band is located? Many web listing pictures are just "representative" not actual. Manufacturer's Part Number:66233H-16 Product Line:Crower Severe-Duty Roller Lifters Link Bar Type:Vertical Lifter Outside Diameter (in):0.903 in. Lifter Offset:None Quantity:Sold as a set of 16. Notes:With pushrod oiling and Hi Pressure Pin Oiling (HIPPO) option.
[Re: 440Jim]
#2879888
01/25/21 02:10 PM
01/25/21 02:10 PM
Cab_Burge
No pictures of them, there in my motor.
[Re: Cab_Burge]
#2880284
01/26/21 08:10 AM
01/26/21 08:10 AM
Posts: 1,629 pa
572charger
pa
ive been using 829 comps for 20 years i just change them out every 3 years
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: 572charger]
#2880592
01/26/21 07:25 PM
01/26/21 07:25 PM
Posts: 16,930 NC
440Jim
NC
ive been using 829 comps for 20 years i just change them out every 3 years How many passes down the track? What spring pressures are you running? What is the shift rpm?
[Re: 440Jim]
#2880608
01/26/21 07:49 PM
01/26/21 07:49 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I had terrible luck with the Comp 829 lifter in a streeter. I have the Comp 848 AMC spec lifter with hippo oiling for 10 years with 1 rebuild.@ 5 years,,, Went 7/10k miles with maybe 20 passes a year before being rebuilt.
