Drum brake master cylinders - reproduction #2868923
01/04/21 04:24 PM
01/04/21 04:24 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Anyone bought one of these and care to comment , good or bad .
Mine has a lid leak I cant seem to stop.
So Im looking at options
https://www.ebay.com/itm/1960s-Mopa...inder-1-Bore-Dodge-Chrysler/362697625380
Re: Drum brake master cylinders - reproduction [Re: gtx6970] #2869143
01/04/21 11:31 PM
01/04/21 11:31 PM
MoreParts Offline
MoreParts  Offline
I could have used one of those years ago before White Post was the leading option. I don't know if those are any good, but the reviews on it seem pretty good. The seller though, not so much. If you get it you can try just swapping over the cap and gasket to see if that solves your problem.
Re: Drum brake master cylinders - reproduction [Re: MoreParts] #2869218
01/05/21 09:42 AM
01/05/21 09:42 AM
VA
dragon slayer Offline
VA
Is it the gasket and lid corrosion, or is it non flat/corrosion on the MC lip?
Re: Drum brake master cylinders - reproduction [Re: dragon slayer] #2870016
01/06/21 07:10 PM
01/06/21 07:10 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I had switched the gasket with another aftermarket reman I have on the shelf. same result a few days later.
no signs of rust or pits on the top edge of the casting. But I have no real way to ck if its flat. Lid lays flat on the table with no gasket in it .
Im going to switch lids next and see what that nets me,
Im kind of thinking I may switch to disc brakes somewhere down the road ,,,,but wasnt planning to do that for another couple years , If at all.
I saw these all new drum brake master cylinders and wondered about quality for the price
Re: Drum brake master cylinders - reproduction [Re: gtx6970] #2870044
01/06/21 08:20 PM
01/06/21 08:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If the MC is off the car, turn it upside down and rub it around on some sandpaper on a dead-flat surface.
It'll be easy to see if it's not flat, and I'd suspect the area at the bolt threads may be raised.
Look closely at the bolt area on the cap as well, verify that the lid seals before the bolt bottoms out.
Even decades ago, I had one that would seep, but I can't swear that it was OEM.
Re: Drum brake master cylinders - reproduction [Re: topside] #2870058
01/06/21 08:47 PM
01/06/21 08:47 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
its still on the car. And I dont have anything flat to ck the top of the casting avail
I will switch lids this week and plan on taking the car out Saturday for the day . maybe I'll get lucky
Re: Drum brake master cylinders - reproduction [Re: gtx6970] #2870072
01/06/21 09:09 PM
01/06/21 09:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
OK - does the area around the threads appear raised ?
A straightedge and feeler gauges is another way to check.
If that area's raised enough, might even be a witness on the seal.
I'm assuming the bolt is proper length, not bottoming out.
Re: Drum brake master cylinders - reproduction [Re: topside] #2870132
01/06/21 10:04 PM
01/06/21 10:04 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
None,
I pulled the lid and sit it on the tool box top. Has a slight rock to it but not hate full.
Switched it one another lid and gasket form a reman unit I have on the shelf .
Time will tell if it fixes it
Re: Drum brake master cylinders - reproduction [Re: gtx6970] #2878953
01/23/21 03:07 PM
01/23/21 03:07 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I have used one and it worked perfectly and looks really good too . I think I got it from Pirate Jacks.
Re: Drum brake master cylinders - reproduction [Re: gtx6970] #2879399
01/24/21 02:43 PM
01/24/21 02:43 PM
moparx Offline
moparx  Offline
i stumbled onto the original lid from my 69 charger. it's now in the pile of "stuff" i no longer have use for.
if yours still develops a leak, PM me here, and i'll check out my lid for straightness. [which i will do anyway, but will do it now if necessary]
beer
Re: Drum brake master cylinders - reproduction [Re: moparx] #2879512
01/24/21 05:42 PM
01/24/21 05:42 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks.
I had a spare unit on the shelf and have switched lids.
But haven't drove it enough to see if i still have a leak.
