ladder bar safety restraints-ideas needed
#2878969
01/23/21 03:29 PM
01/23/21 03:29 PM
Posts: 19,591 north of coder
moparx
i don't have room for the type of restraints that are a flat "C" shape that bolts onto tabs welded onto the upper and lower bars. any other ideas out there ? alston used to offer a couple of tabs that welded to the bar sides with spacers that allowed the bolts to be tightened up and still allow the bars to rotate, but i can't find them now. i may be looking in the wrong place, or calling them by the wrong name. as always, TIA fellows !
Re: ladder bar safety restraints-ideas needed
[Re: HR3128]
#2879001
01/23/21 04:06 PM
01/23/21 04:06 PM
moparx
that's it ! i was looking under alston, not chassis works. thank you sir ! i'm pretty sure i can use those. the only thing that may screw me up, is if the bolt is 3/4", as i need a set for a 5/8" bolt. i'll call them to find out. thanks again !
[Re: HR3128]
#2879104
01/23/21 06:31 PM
01/23/21 06:31 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
My car is an Alston chassis. That is the type of ladder bar ends on it. Work good....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#2879123
01/23/21 07:14 PM
01/23/21 07:14 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
My car is an Alston chassis. That is the type of ladder bar ends on it. Work good.... Me too. I like them.
[Re: markz528]
#2879251
01/24/21 09:56 AM
01/24/21 09:56 AM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
They work great and don't take a lot of room. Hope you never need them..
6.50 @105.26
[Re: gsmopar]
#2879437
01/24/21 03:27 PM
01/24/21 03:27 PM
moparx
hmmm. never thought of that. i would think a guy should use a tab on both sides of the bar ? but two kits ? but then, you would have to modify a wrench to tighten the lock nut ? [get the wrench between the tabs]
[Re: gsmopar]
#2881717
01/29/21 01:32 PM
01/29/21 01:32 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
Kinda defeats the purpose... you basically took most if not all the strength out of the tab. I use these on all my ladder bar installs, I don't weld them on until the rear end is set in place. As far as heim replacement goes, it really depends on the use, higher HP and amount of used dictate. even then its a crap shoot.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: racerx]
#2882070
01/30/21 03:20 PM
01/30/21 03:20 PM
moparx
This thread has me thinking ...how often do you all replace the hems on you ladder bar cars? I have a friend that has a 4.70-4.80 car and i remember him saying he replace his every year(i thought that was over kill)am i wrong?.......I did not start a new thread so i thought i'll piggy back off this one sense it's slightly off subject. not a problem X ! my concern for adding these safety restraints is in the event i get this [never ending !] project done, and end up with an engine that will tax the rod ends, i don't want the possibility of a "pole vault" event if the rod end breaks. especially at speed. with that said, and your question about rod end replacement, is it possible to miss a shank thread starting to fail, yet still have no movement or wear in the ball and head of the joint ?
[Re: racerx]
#2882354
01/31/21 12:24 PM
01/31/21 12:24 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
I would imagine a high horsepower /heavy car/hooking track can put a lot of stress on those hems. Everything goes through those ends
