Modifying a std fuel regulator for boost reference #2879243
01/24/21 09:35 AM
01/24/21 09:35 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi.
Anyone modified a std regulator for boost reference by tapping a hole in the housing above the diaphragm for a small push on fitting ?
Would it work?
Edit: A bit more info, it's a Aeromotive P/N 13208: Pro-Stock, 4-Port Regulator. It has small hole above the diaphragm in the top housing. I'm guessing it's for referencing to atmosphere so that's where I'm thinking of tapping it.
TIA.
Re: Modifying a std fuel regulator for boost reference [Re: Tig] #2879246
01/24/21 09:46 AM
01/24/21 09:46 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't see any reason that wouldn't work. A friend did the same thing to a mechanical fuel pump when adding boost and it worked just fine.
68 Barracuda Formula S 340
Re: Modifying a std fuel regulator for boost reference [Re: Tig] #2879268
01/24/21 11:02 AM
01/24/21 11:02 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I did that once to an adjustable regulator, the only thing I had to do was put an o-ring under the jam nut on the adjustment screw threads. It was leaking air through the threads causing a boost/vaccum leak.
Re: Modifying a std fuel regulator for boost reference [Re: Uberpube] #2879432
01/24/21 03:17 PM
01/24/21 03:17 PM
moparx Offline
moparx  Offline
i was thinking the same thing, use an o-ring that fit the threads snugly, then use a washer above the o-ring to prevent the lock nut from cutting the o-ring.
beer
Re: Modifying a std fuel regulator for boost reference [Re: Tig] #2879657
01/24/21 10:25 PM
01/24/21 10:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
Are you feeling lucky with your fuel regulator? work
I wouldn't mess with it, I know buying one in England isn't as easy as it is here but it is January over their also, correct whistling grin
Re: Modifying a std fuel regulator for boost reference [Re: Cab_Burge] #2880059
01/25/21 06:30 PM
01/25/21 06:30 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Thanks for the replies. I'll have a look at the regulator, see how it is to strip it down. There is already a hole in the body, above the diaphragm. If it looks like adding a fitting there will foul the internal mechanism, then it cant be done. That particular model doesn't seem to have a boost referenced equivalent. I want to reference the regulator to the sealed scoop pressure. Not sure how much pressure it will generate but the combo is pretty sensitive to fuel bowl level.
