Modifying a std fuel regulator for boost reference
#2879243
01/24/21 09:35 AM
01/24/21 09:35 AM
Posts: 2,917 A shed in England
Tig
A shed in England
Hi. Anyone modified a std regulator for boost reference by tapping a hole in the housing above the diaphragm for a small push on fitting ? Would it work? Edit: A bit more info, it's a Aeromotive P/N 13208: Pro-Stock, 4-Port Regulator. It has small hole above the diaphragm in the top housing. I'm guessing it's for referencing to atmosphere so that's where I'm thinking of tapping it. TIA.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Modifying a std fuel regulator for boost reference
[Re: Tig]
#2879246
01/24/21 09:46 AM
01/24/21 09:46 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I don't see any reason that wouldn't work. A friend did the same thing to a mechanical fuel pump when adding boost and it worked just fine.
68 Barracuda Formula S 340
[Re: Cab_Burge]
#2880059
01/25/21 06:30 PM
01/25/21 06:30 PM
Tig
A shed in England
Thanks for the replies. I'll have a look at the regulator, see how it is to strip it down. There is already a hole in the body, above the diaphragm. If it looks like adding a fitting there will foul the internal mechanism, then it cant be done. That particular model doesn't seem to have a boost referenced equivalent. I want to reference the regulator to the sealed scoop pressure. Not sure how much pressure it will generate but the combo is pretty sensitive to fuel bowl level.
