Direct Connection Manual Valve body ?
#2879185
01/23/21 10:33 PM
01/23/21 10:33 PM
Posts: 1,325 VA
dragon slayer
VA
Does any one know the casting number used on the transfer plate for the Mopar kit that was sold in the day? I have seen some info on this and I have reviewed the Race manual section. I have one of these modified VB, but not sure what year I have.
This was a bastardized race transmissions. It has a 69 Case, but had 1976 internal assembly by cast date and configuration. I finally got the valve body apart and it was a modified (reverse manual) VB like the DC race manual.
It has a VB with 2892"3"48 casting number. The 3 is upside down. Late 68 casting date and has the 69 plastic insulator on the rooster. Relief ball and spring. Makes sense for a 69 VB. Does not look like it has been modified in any way other than set up like the diagram in the race manual.
The transfer plate is 2801295 casting with a late 66 casting date This would match for 67, but maybe it was the same for a 69-70. It also has an extra machining not in the race manual that had a plastic check ball in it. What is that for?
The race manual had 4 kits. 62-65, 66-68, 69-70, 71-73. So I am not sure if the transfer plate was different for each kit or the same.
Also, is there any way to identify the steel plate as correct? No part number on it. Thanks,
Re: Direct Connection Manual Valve body ?
[Re: dragon slayer]
#2879343
01/24/21 01:07 PM
01/24/21 01:07 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
The shift kit that they had for my trans, 46rh/518/727, was made by Turbo Action. Maybe they did the body too.
Carl Kessel
[Re: dragon slayer]
#2879901
01/25/21 02:22 PM
01/25/21 02:22 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the extra machining is the area circled in red below, this a later update called "the instant shift ball". The original RMVB had a delay when shifting from 2 to 3, this update cures the problem.
