Dana car four speed car with 22 inch radiator?
#2876324
01/18/21 10:03 PM
01/18/21 10:03 PM
Posts: 10,231 Someplace you aren't
SomeCarGuy
This wasn’t possible, right? 440 4 speed got Dana and a 26 always I thought. No fender tag or sheet present to see anything.
I want my fair share
Re: Dana car four speed car with 22 inch radiator?
[Re: SomeCarGuy]
#2876338
01/18/21 10:39 PM
01/18/21 10:39 PM
Posts: 643 southern conn
1969gtx
southern conn
I know of a 69 b body hemi 4 speed with a22" rad support that was looked at a hi end mopar Inspector stats it very possible this car has a fender tag with 26 on it
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: 1969gtx]
#2876346
01/18/21 10:56 PM
01/18/21 10:56 PM
SomeCarGuy
Interesting. I hadn’t seen a gtx with this before. Has reverse light. Anything can be swapped of course. I see a booger weld on the hump underneath. I had a factory four speed that had a crappy look in that area, but it wasn’t a super solid car to begin with so I didn’t pay much attention to it. Thought it could’ve been bent and rusted over the years.
[Re: SomeCarGuy]
#2876370
01/18/21 11:49 PM
01/18/21 11:49 PM
Posts: 21,485 It's a dry heat
gtx6970
It's a dry heat
Those welds are fresh. In person one could tell if it were original or not. MY gut says not. And without a tag to back it up it will always be tainted as a conversion . IMO< keep looking
[Re: NITROUSN]
#2876384
01/19/21 01:19 AM
01/19/21 01:19 AM
Posts: 31,069 Oregon
AndyF
My last 68 GTX the 4 speed cut out looked like it was done by a 3 year old with a cutting torch. The welded in hump was also poorly welded. Car was original and untouched. The four speed cut out on my '65 Coronet looks like it was made with an axe. I used to think that back yard bob hacked the car up but over time I realized that they were just that crude at the factory. They didn't care how it looked, just "got er done".
[Re: SomeCarGuy]
#2876386
01/19/21 01:26 AM
01/19/21 01:26 AM
AndyF
This wasn’t possible, right? 440 4 speed got Dana and a 26 always I thought. No fender tag or sheet present to see anything. Well if the core support is there then the stamped numbers should be there also so that would be one way to verify if it was original. I'd be surprised if 26 inch radiators were mandatory. Seemed like the factory was always trying to save money by using the smaller radiator.
[Re: 6bblgt]
#2876398
01/19/21 06:05 AM
01/19/21 06:05 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Wow, they sure ain't 50 year old factory welds! No factory guys would under the car with a mig welder in 1969... The burn rings are fresh and not underseal to dis-guise the work even? I can just imagine the folks on the production line saying '' some numpty has ordered a 4-speed '' '' What is up with these morons, they will hate it after a week or two''... (thats coming out) Have you ever tried doing a hill start in San Fran with a stick car? What plonker thought that you could use a floor 'parking brake' with a stick car...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: SomeCarGuy]
#2876471
01/19/21 11:02 AM
01/19/21 11:02 AM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
It also shows the B body 440 having the 22 inch. So could or should can be looked at as either or. That is someones spread sheet. The factory manual shows it but makes no mention of transmission. Unless that radiator was made with the cooler and sold in either application.
[Re: moparx]
#2876642
01/19/21 03:21 PM
01/19/21 03:21 PM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
Just as Andy F said ... Even without a fender tag or a build sheet I would check to see if the stamping on the trunk lip matches the radiator support number.
The number on my original '68 RR from Lynch Road A8R279740 on both the radiator support and he trunk lip
A = Lynch Road built 8 = model year R = body style (Belvedere) 279740 = Shipping Order #
The location of the radiator support frame should be upside down facing the engine and stamped near the area of the upper radiator hose.
If that number matches the stamped number on the trunk lid stamped on the drivers side under the rubber weather strip then it came with a 22' radiator.
Now if the radiator support or the drivers side fender have been replace....it remains a question
Just my $.02
Remember - 2 wrongs don't make a right - but 3 rights make a left!
[Re: NITROUSN]
#2876678
01/19/21 03:59 PM
01/19/21 03:59 PM
Posts: 17,521 Las Vegas, NV
6bblgt
Las Vegas, NV
The 68 parts manual also shows Full size Chrysler, Plymouth, Dodge with the 440 having a 2898063 radiator with the 22 inch core. So yes the GTX could have a 22 inch according to the parts manual. As said if you were a betting man the 26 should win the bet. However there is no doubt they are out there. It would be nice to have more information to back it up. The radiator may have numbers that could help prove or un-prove its originality. so much misinformation the GTX isn't a full-size model the 4-speed manual was NOT available in a C-body with a 440
