Page 1 of 3 1 2 3
Dana car four speed car with 22 inch radiator? #2876324
01/18/21 10:03 PM
01/18/21 10:03 PM
Someplace you aren't
SomeCarGuy Offline OP
This wasn’t possible, right? 440 4 speed got Dana and a 26 always I thought. No fender tag or sheet present to see anything.
I want my fair share
Re: Dana car four speed car with 22 inch radiator? [Re: SomeCarGuy] #2876336
01/18/21 10:36 PM
01/18/21 10:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
My 68 parts manual shows a 22 inch 2949053 as a possibility. Most likely a low-line manual had it.
Re: Dana car four speed car with 22 inch radiator? [Re: SomeCarGuy] #2876338
01/18/21 10:39 PM
01/18/21 10:39 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
I know of a 69 b body hemi 4 speed with a22" rad support that was looked at a hi end mopar Inspector stats it very possible this car has a fender tag with 26 on it
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Dana car four speed car with 22 inch radiator? [Re: 1969gtx] #2876346
01/18/21 10:56 PM
01/18/21 10:56 PM
Interesting. I hadn’t seen a gtx with this before. Has reverse light. Anything can be swapped of course. I see a booger weld on the hump underneath. I had a factory four speed that had a crappy look in that area, but it wasn’t a super solid car to begin with so I didn’t pay much attention to it. Thought it could’ve been bent and rusted over the years.
Re: Dana car four speed car with 22 inch radiator? [Re: SomeCarGuy] #2876350
01/18/21 11:04 PM
01/18/21 11:04 PM
N
NITROUSN Offline
NITROUSN  Offline
N
My last 68 GTX the 4 speed cut out looked like it was done by a 3 year old with a cutting torch. The welded in hump was also poorly welded. Car was original and untouched.
Re: Dana car four speed car with 22 inch radiator? [Re: NITROUSN] #2876363
01/18/21 11:30 PM
01/18/21 11:30 PM
Look like this?
Re: Dana car four speed car with 22 inch radiator? [Re: SomeCarGuy] #2876370
01/18/21 11:49 PM
01/18/21 11:49 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by SomeCarGuy
Look like this?
Those welds are fresh.
In person one could tell if it were original or not.
MY gut says not. And without a tag to back it up it will always be tainted as a conversion .
IMO< keep looking
Re: Dana car four speed car with 22 inch radiator? [Re: NITROUSN] #2876384
01/19/21 01:19 AM
01/19/21 01:19 AM
AndyF Offline
AndyF  Offline
The four speed cut out on my '65 Coronet looks like it was made with an axe. I used to think that back yard bob hacked the car up but over time I realized that they were just that crude at the factory. They didn't care how it looked, just "got er done".
Re: Dana car four speed car with 22 inch radiator? [Re: SomeCarGuy] #2876386
01/19/21 01:26 AM
01/19/21 01:26 AM
AndyF Offline
AndyF  Offline
Well if the core support is there then the stamped numbers should be there also so that would be one way to verify if it was original. I'd be surprised if 26 inch radiators were mandatory. Seemed like the factory was always trying to save money by using the smaller radiator.
Re: Dana car four speed car with 22 inch radiator? [Re: AndyF] #2876387
01/19/21 01:32 AM
01/19/21 01:32 AM
This site shows it should be a 26.
[url]http://www.mymopar.com/radiatorspecs.htm[url]
I do think the welds look fresh enough to be suspect. Engine claimed to be numbers, trans is not.
Re: Dana car four speed car with 22 inch radiator? [Re: AndyF] #2876391
01/19/21 01:44 AM
01/19/21 01:44 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
ANY 1966-'72 B-BODY (or E-BODY) factory equipped with a 440 and a 4-speed manual transmission SHOULD have a 26" radiator/core support and DANA60 rear axle
exceptions exist but they are extremely RARE - they should be viewed under a microscope & the question asked WHY? and is it a real factory built example or a decades old "FIX" for any number of reasons
Re: Dana car four speed car with 22 inch radiator? [Re: 6bblgt] #2876398
01/19/21 06:05 AM
01/19/21 06:05 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Wow, they sure ain't 50 year old factory welds!
No factory guys would under the car with a mig welder in 1969...
The burn rings are fresh and not underseal to dis-guise the work even?
I can just imagine the folks on the production line saying '' some numpty has ordered a 4-speed ''
'' What is up with these morons, they will hate it after a week or two''... green (thats coming out)
Have you ever tried doing a hill start in San Fran with a stick car?
What plonker thought that you could use a floor 'parking brake' with a stick car... fan
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Dana car four speed car with 22 inch radiator? [Re: Gtxxjon] #2876424
01/19/21 09:39 AM
01/19/21 09:39 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Four speed humps were factory welded in from the top. Welds on the underside would not be original. And FWIW overhead welds take skill so if done by an unskilled welder, they will look like sh!t.
Re: Dana car four speed car with 22 inch radiator? [Re: SomeCarGuy] #2876459
01/19/21 10:43 AM
01/19/21 10:43 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Look like this?
Basically yes, except your picture has fresher welds.
Re: Dana car four speed car with 22 inch radiator? [Re: NITROUSN] #2876468
01/19/21 10:57 AM
01/19/21 10:57 AM
N
NITROUSN Offline
NITROUSN  Offline
N
The 68 parts manual also shows Full size Chrysler, Plymouth, Dodge with the 440 having a 2898063 radiator with the 22 inch core. So yes the GTX could have a 22 inch according to the parts manual. As said if you were a betting man the 26 should win the bet. However there is no doubt they are out there. It would be nice to have more information to back it up. The radiator may have numbers that could help prove or un-prove its originality.
Re: Dana car four speed car with 22 inch radiator? [Re: NITROUSN] #2876469
01/19/21 10:57 AM
01/19/21 10:57 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Also, In 1968 the block matches the sequence number on the fender tag NOT the vin correct ?
Same goes for the body numbers stamped in the radiator support / trunk lip ?
Re: Dana car four speed car with 22 inch radiator? [Re: SomeCarGuy] #2876471
01/19/21 11:02 AM
01/19/21 11:02 AM
N
NITROUSN Offline
NITROUSN  Offline
N
It also shows the B body 440 having the 22 inch. So could or should can be looked at as either or. That is someones spread sheet. The factory manual shows it but makes no mention of transmission. Unless that radiator was made with the cooler and sold in either application.
Re: Dana car four speed car with 22 inch radiator? [Re: Gtxxjon] #2876593
01/19/21 02:14 PM
01/19/21 02:14 PM
moparx Offline
moparx  Offline
umm, the bad guys in "Bullet" ? biggrin
beer
Re: Dana car four speed car with 22 inch radiator? [Re: moparx] #2876642
01/19/21 03:21 PM
01/19/21 03:21 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Just as Andy F said ... Even without a fender tag or a build sheet I would check to see if the stamping on the trunk lip matches the radiator support number.
The number on my original '68 RR from Lynch Road A8R279740 on both the radiator support and he trunk lip
A = Lynch Road built
8 = model year
R = body style (Belvedere)
279740 = Shipping Order #
The location of the radiator support frame should be upside down facing the engine and stamped near the area of the upper radiator hose.
If that number matches the stamped number on the trunk lid stamped on the drivers side under the rubber weather strip then it came with a 22' radiator.
Now if the radiator support or the drivers side fender have been replace....it remains a question
Just my $.02
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Dana car four speed car with 22 inch radiator? [Re: NITROUSN] #2876678
01/19/21 03:59 PM
01/19/21 03:59 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
so much misinformation spank
the GTX isn't a full-size model
the 4-speed manual was NOT available in a C-body with a 440
Page 1 of 3 1 2 3
